Spoiler installation question
Old Oct 9, 2005 | 08:03 PM
The Phoenix's Avatar
Hello everybody,
I got an used G35 from my local Infiniti dealer, and they installed a spoiler for me on it. It seems to be the standard G35 spoiler (with the break light hooked-up), but I find it a bit loose. By looking at the installation it's only screwed with 2 boat and sitting on some sort of protecting foam.
Everytime I shut a front door, it shakes a bit (ok, it's not loosed, but not as tight as it would be with 4 nuts). Can anyone confirm how it's installed on an Aero? (2 or 4 nuts)
thanks,
Old Oct 9, 2005 | 08:31 PM
iamnsxtc's Avatar
Originally Posted by The Phoenix
Hello everybody,
thanks,
I just installed the stock wing on my 05 sedan. It has two bolts up front and two snap-in connectors in the rear with two-sided tape.
Old Oct 9, 2005 | 08:34 PM
Noise?
Does your wing shakes a bit when you shut the front doors? It seems to be installed as you described, but the 2 snap-in connectors at the rear aren't rock solid and the on the side it sits on some sort of grey foam (very thin). When I open the trunk, it seems very solid, but when I shut a front door, it shakes and seems shaky.
Old Oct 9, 2005 | 09:58 PM
vrsc's Avatar
My OEM spoiler seems to shake as well. Is this normal?
Old Oct 10, 2005 | 04:55 AM
G35HAWAII's Avatar
Hey Guys,
Just installed my OEM spoiler on my 05 Sedan. Dealer will install using 2 bolts and 2 plastic clips, the grey foam is just that "grey foam". I opt to use the 2 bolts but used 2-way sponge tape (available at most bodyshops) instead of the clips. Spoiler is solid, no shaking at all.
Old Oct 10, 2005 | 06:51 AM
JustBrilliantX's Avatar
Misanthropic nut-cracker
From: On the water at the "Jersey Shore"...Toms River
Two side tape (grey foam) is probably shot and I'm doubting that the two rear clips are in place. Check out my old post https://g35driver.com/forums/showthr...950#post408950
Old Oct 10, 2005 | 03:05 PM
LuXXXz's Avatar
i installed the spoiler myself with 4 screws two on each side of the spoiler
Old Oct 11, 2005 | 02:40 AM
EverybodyWildOu's Avatar
Mine was tight and definitely in place. Remove your spoiler and buy the plastic pieces from the dealer. They must be 5 bucks at most. I forgot what theyre called though...
jsimonk
Dec 22, 2023 03:49 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
nickmcc123
Jul 29, 2015 05:14 PM
