350Z Header?
Old Oct 11, 2005 | 12:53 AM
MI SO FST's Avatar
350Z Header?
Would this be an upgrade at all for a 03 Sedan? I'm getting a mid pipe from a friend and was wondering if the header would also make some sort of upgrade. I know that the mid pipe from a 350Z would have to be extended.
I also did a Search and came up with nothing.
Old Oct 11, 2005 | 01:24 AM
Hyde's Avatar
350z headers should be direct bolt on
Old Oct 11, 2005 | 01:27 AM
dklau33's Avatar
If you are talking about the OEM headers then they are the same as the G35's. No upgrade. Same thing for the Y-pipe.
Old Oct 11, 2005 | 03:01 AM
luongdmd's Avatar
the mid is going to be extended around 8 inches. i got myslf the 350z stillen cat back and it was 8 inches in the mid and 2 inches at the tip. pain in the b**t, but (no pun intended) it was well worth it.......
Old Oct 11, 2005 | 09:56 AM
MI SO FST's Avatar
yes I was talking about the OEM header. The reason I want the Mid (B) pipe is to get that coupe/350Z sound on the sedan. Changing that out will give me that sound, correct?
Old Oct 11, 2005 | 03:45 PM
dklau33's Avatar
Yes, do a search on the terms "coupe mid pipe" and you'll find plenty of hits. It will make your sedan sound more coupe like but not exactly like it. I personally didn't like how it sounded so I just had my huge OEM resonator replaced with a Magnaflow resonator. Shaved about 15-20 lbs. of weight too.
Old Oct 12, 2005 | 01:31 AM
EverybodyWildOu's Avatar
If you get on it it will sound little more like the coupe but without the high pitch.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
DRG35R
Jan 31, 2016 07:14 AM
magnetism80
Jan 27, 2016 12:57 PM
