infiniti parts?? pictures??
Old Oct 17, 2005 | 03:00 PM
Audible Mayhem's Avatar
has anyone found a link to pictures showing parts off a sedan, with the part numbers, like when you go into the dealership and need a gasket, they print out all the parts around where you need a gasket and then show it to you..
for instance if you need a plenum gasket, they will show you a picture with a plenum taking all apart and the part numbers for all the parts????
thanks in advance
Old Oct 17, 2005 | 03:53 PM
i was tryin to figure out exactly what the box does in the back passenger side, under the trunk, it has two vacuum lines running into it, and a wiring harness runs above it, it looks like some evap stuff, just wanted to know exactly what it did?? no real reason, it just looks outta place back there....
thanks in advance
also trying to take off the back bumper and couldnt find the main clips or nuts that come off to get the whole thing off....
tiguy99
Mar 1, 2016 11:42 AM
Karl_g335x
Aug 3, 2015 03:43 PM
joedaddy1
Jul 28, 2015 02:58 PM
