Would 19x8 by 19X10 Rims Fit A Sedan?
Old Oct 20, 2005 | 06:40 PM
MikeyMike's Avatar
Rollin On Dubz
19x8 F and 19x10 R, 245/35s up front and 275/30s on a sedan?
They are DPE's, Offset is unknown. I know the fenders would most likely have to be rolled, but after doing that any of you guys know if they fit?
I keep trying to search, but I couldn't find anything on this.
Thanks Much!
Old Oct 20, 2005 | 06:45 PM
G35Lin's Avatar
Multi-Spoked Mod
i know X10s will fit the rears with proper offsets....
friend did it with 20s
ed
Old Oct 20, 2005 | 06:58 PM
shodog's Avatar
it will be tight and you will most likely have to roll your fender. most people use a 45mm offset for the rears
Old Oct 20, 2005 | 07:00 PM
vodkarocket's Avatar
Modded Member
You will need more than a 45mm offset for a 10" wide wheel.
Old Oct 20, 2005 | 07:48 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
W/O offsets of the wheels you're considering... there is no conclusive answer.
I have 8.5" +42 on the front with 255s
-that's as tight as you can go to the suspension w/o rubbing: +35 would be ideal.
- 10" will fit no problem on the back; with the right offset.
There's tons of room to the inside.
It'll probably require somewhere between a +50 to +55 (never actually figured it out)
Old Oct 20, 2005 | 08:30 PM
Modded Member
When I spoke with Vince from iForged, I was told that they were able to get a set of 10" wide wheels to fit with a 49mm offset with fender rolling.
Old Oct 20, 2005 | 08:50 PM
MikeyMike's Avatar
Rollin On Dubz
The thing is DPE doesn't provide offsets, I want to get them used off a guy, so it's not like I can ask the company if they'll work.
So should i pull the trigger?
Old Oct 20, 2005 | 11:05 PM
InTgr8r's Avatar
I presume the owner is too far away to do a trial fit?
If thats the case get him to measure the offsets.
((face of flange to inner bead )- half the width)
Old Oct 20, 2005 | 11:46 PM
DaveB's Avatar
You realize after doing this type of stagger, your G will understeer worse than your Aunt's 89 Civic sedan with S-rated tires, right?
Old Oct 21, 2005 | 12:04 AM
MikeyMike's Avatar
Rollin On Dubz
Really, that bad?
Old Oct 21, 2005 | 12:18 AM
papagz's Avatar
rears on my car are +35 but not sure about the fronts. they BARELY and i mean barely clear the brembos
Old Oct 21, 2005 | 12:31 AM
skeleton_cru's Avatar
Sedan
I think +55mm was the consensus. There are a couple of guys running 10" wide in the rear, I just can't remember who they are.
Old Oct 21, 2005 | 12:49 AM
Modded Member
Yes, and you have a coupe so your offsets are completely irrelevant.
Old Oct 21, 2005 | 12:51 AM
Modded Member
I can only think of one off the top of my head, but I can't remember the user name. It's HKS-something or other!
He has used to have a set of 19x10" Volk VS-XX's, but moved on to 20x10" Volk Rezax II's.
Old Oct 21, 2005 | 02:45 AM
MikeyMike's Avatar
Rollin On Dubz
Is that kinda stagger really that extreme? 8 front and 10 back? I would think having such wide rears would equal really good handling.
