Grinding Noise - Rear Wheels
Old Sep 22, 2009 | 01:05 PM
PAIXAO's Avatar
Sounds like a bad bearing to me also.
Old Sep 22, 2009 | 04:12 PM
thumper10s's Avatar
there is no play in the wheel,ie i cant rock it back and forth, i am leaning towards new rotors-i know the fronts are getting worn
Old Sep 22, 2009 | 05:38 PM
DaveB's Avatar
I know that on some Subaru's, rust builds up between the inner portion of the rotor hub and the brake backing plate. The issue only shows itself on tight slow speed turns and it has a metallic roaring sound and is often mistaken for worn bearings. Lots of people have wasted hundreds of dollars on bearing replacements only to find out the fix was simple after a couple of minutes of air grinding. My wife's 98 LGT wagon currently has the problem. The issue you're having may be similar.
I'd suggest taking the caliper and rotor off and closing inspecting everything of wear, etching/rubbing, etc. It sounds like the issue comes into play when the rotors get warmed up and causes some sort of clearance problem. Pay close attention to the internal e-brake system as well. That might be the cause of the problem.
Old Sep 22, 2009 | 05:46 PM
thumper10s's Avatar
^^^ thanks for the input
Old Sep 22, 2009 | 06:52 PM
AARONHL's Avatar
Or the pads have no meat left?
Old Oct 2, 2009 | 03:29 PM
mr_ecktid's Avatar
doh, wish i had read this before i brought my car to the shop this past week
count me in as one of the suckers paying several hundred to have the rear wheel bearings replaced..
what is air grinding?
Old Oct 2, 2009 | 04:40 PM
thumper10s's Avatar
air tools my friend, an invention from the gods, saving me time for ten+ years
Old Oct 2, 2009 | 06:20 PM
mr_ecktid's Avatar
ooo ic
oh and an update, so the mechanics had told me my rear wheel bearings were shot and had scratched into my rotors. so hopefully they were really messed up and i didnt just waste a bunch of money on wheel bearings that werent needed
Old Oct 2, 2009 | 06:29 PM
thumper10s's Avatar
what kind of noises were you hearing from this problem?
Old Mar 28, 2011 | 06:13 PM
bsavage's Avatar
Thumper,
you ever figure out this problem? I'm having the same issue....
Brian
rezendvous420
May 31, 2020 01:26 PM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
Bean_VQ35DE
Jul 22, 2015 07:06 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
