i need to ask this again
Old Oct 25, 2005 | 08:22 PM
LuXXXz's Avatar
i wanted to find out about the headlights, can i remove that little clearance light in the headlight housing,
i hate how it looks yellow and the HIDs are nice and purple
can this be done??
Old Oct 25, 2005 | 09:24 PM
vodkarocket's Avatar
Modded Member
Yes, it can be done.
Browse through the threads in the "lighting" section, and you will find many resources and DIY's for this.
Old Oct 25, 2005 | 09:56 PM
Dudefish's Avatar
seems like a lot of trouble to remove a little bitty light bulb, but hey its your car
Old Oct 26, 2005 | 08:16 AM
skeleton_cru's Avatar
Sedan
You could always replace it with a whiter bulb.
Old Oct 26, 2005 | 01:06 PM
LuXXXz's Avatar
thanks for the feedback ill check out the lighting forum
is the bulb hard to get to??
Old Oct 26, 2005 | 01:11 PM
da mayor's Avatar
no it is a little tight but you can reach it.
Old Oct 26, 2005 | 01:13 PM
LuXXXz's Avatar
so if i just take them out or if i unplug them will everything still work the same???
