OK... all this talk about spring rates and I'm still confused.
What are the spring rates for the 2005 6MT sedan?
Anybody running 350Z springs off a 2003-2004 in their 2005 6MT that can tell me the actual drop and comment on the ride?
Jun
Jun
Nothing happened to indicate that anything changed in the suspension other then Infiniti's claim that all 05 sedan's have stiffer sway bars. And I'll bet money that only the front bar is stiffer.
If you want more assurance go out to your car pull one front tire and one rear tire. Write down a front shock part and one rear shock part number and post them here. I'll check the part numbers with the sedan sport shocks I have in my garage. While your at it, see if you can write down what color the dot's are on the front and rear springs, Nissan uses color coding to ID their springs. If the spring is turned the wrong way you of course won't be able to see the dot's, but you never know.
