Decsions between 245/40/19's or 245/35/19's and opinions of brand tires
Old Nov 4, 2005 | 11:54 AM
vrsc's Avatar
^^^^That is what I meant, too large of a sidewall which would look too fat.. I have 8.5 width and +46 offset. Look at my first post and you will see that I have included tire size comparisons.
Old Nov 4, 2005 | 12:31 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Originally Posted by vegasG35sedan
good link.. I was looking for a calc to give me the circumference of tires. I want to upgrade to 18's or 19's but keep the factory oem circumference. Tired of doing it manually
Here's another one for you.
This one builds a table.....
LINKY
Old Nov 4, 2005 | 02:08 PM
jran76's Avatar
I agree that the 245/40 will be great if you do not plan to lower, about 1% larger than stock, but A OK....
I had the Falken GBR-451's, they were a pretty good tire for the money. I had no problems, and I got about 18,000 miles on them. My car is lowered and slightly out of alignment because of that.
They are not on the level of the S-03's or T1-R, but good for the money. The BFG KDW2's sound like a good tire also.
Old Nov 5, 2005 | 02:23 PM
vrsc's Avatar
I decided to go with the Falken GBR-451's in 245/40/19. After much research these seem to be a great tire for the money, have great dry and wet handling and wear OK. I have heard that they are not as quiet as the Falken ST-115's but not as load as the stock goodyear RS-A's I found more positive info on the falkens than I did on the Toyo T1-R.
Old Nov 5, 2005 | 06:21 PM
skeleton_cru's Avatar
Sedan
It surprises me that you stuck with Falken after your last experience.
Old Nov 5, 2005 | 11:06 PM
vrsc's Avatar
I spoke with the Falken tech and he mentioned that the ST-115's had a softer sidewall and our G has a sensitive camber (even dealer and tire place said this). I was interested in the FK-451's and he said that I should be straight. If not, I can try another tire.
Old Nov 6, 2005 | 04:45 AM
Augy's Avatar
I have had Nitto, Kuhmo and Pirelli tires. I got Goodyear Eagle F1's tires when I got my wheels and they are amazing!
Old Nov 7, 2005 | 02:11 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
Originally Posted by skeleton_cru
I have the Bridgestone S-03's and I have been very satisfied with the performance in wet and dry conditions. They are pricey though.
+1 cru... I got S0-3's too, overall they are a great tire. As cru said they are a little pricey, but definitely worth it. Wet or dry they stick to the road very well.
Old Nov 7, 2005 | 07:36 PM
jran76's Avatar
You should get 15,000+ miles on the Falken's. I got around 18,000 on mine, and my car is lowered with the Nismo suspension, and therefore is out of factory specs.
I did rotate every 3,000 miles, or so. Also, just something I noticed about the 451's in heavy rain, they do seem to hydroplane some, worse than say S-03's.
Old Nov 7, 2005 | 11:28 PM
last time i checked S0-3's dont hydroplane. Jran... have you personally experienced the S0-3's hydroplane??? If not i'd like to know where you got that info from.
Old Nov 8, 2005 | 11:29 AM
jran76's Avatar
Errrr... My point was that the S-03's DO NOT hydroplane. The Falken 451's are worse than the S-03's in terms of hydroplaning. Sorry for the confusion.
I had S-03's on my 350Z and rarely, if ever, hydroplaned. I could tell (especially on one particular road in heavy rain) that the 451's had a better chance of hydroplaning.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
Footballmania32
19 Inch
Aug 13, 2015 03:07 PM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
