1/4 mile times 05 sedan results..
Old Nov 5, 2005 | 02:39 AM
vegasG35sedan's Avatar
05-G35 Sedan 5AT
well here at the ETs for my stock 05 sedan. a good base for mods
2 runs 15.5 both times
About 65 degees
15.512 reaction time .329
15.554 R/T .364
Old Nov 5, 2005 | 12:19 PM
DaveB's Avatar
Hmmmm....what's the elevation of this track? Were you running at Firebird? I know Firebird sits at about 2,200' above sea level so that doesn't help things and if you ran last night, conditions were such that the density altitude was around 3,200 feet which is enough to suck out about .5 seconds. Either way, it sounds like your ETs are still a little high (most likely low 15s at sea level).
What were your 60 foots like?
Trapspeed?
Were you holding 3rd?
How were you launching?
Old Nov 5, 2005 | 02:46 PM
kensandell's Avatar
Time Slips attached -- Stock 05' G35X
Old Nov 5, 2005 | 03:16 PM
05-G35 Sedan 5AT
Trapspeed?
It was here in VEgas at the Las Vegas Motor Sport track
elevation is probably 2200' or real close to it..
If I can figure out how to upload or attach the slips I will..
05-G35 Sedan 5AT
cant read them at all
Old Nov 5, 2005 | 03:29 PM
kensandell's Avatar
That's true...
Attached Thumbnails 1/4 mile times 05 sedan results..-timeslips.jpg
Old Nov 5, 2005 | 03:58 PM
Sumlime311's Avatar
is it just me or does that time seem a little slow???
Old Nov 5, 2005 | 04:06 PM
05-G35 Sedan 5AT
15.5 is respectable. Its completly stock.. 15s are what stock 5.0 muatangs run out here. WRX Sti's run mid to high 14s
Some times people forget about climate and ambiant conditions when they see ETs.
Thats all a stock g35 will do. Not much you can do with the 5AT but get off the line as fast as possible and shift near the redline..
Attached Thumbnails 1/4 mile times 05 sedan results..-dragsresized.jpg
Old Nov 5, 2005 | 10:33 PM
Audible Mayhem's Avatar
14.2 bone stock with an auto sedan. you should be running at least mid 14s
throw some nitrous on there, i was running 13.0 at 110 twice with no traction, got a 12.9 at 96, i hit my brakes at the end and all, just to show everyone i had a bad run. they were like dude. why did you hit your brakes, i said "it was a crappy run man" they said you ran 12.9
i will run 12.6 12.7 for sure next time i go. god i love nitrous
100 shot, skunk2 spacer, test pipes, injen CAI, and evo 2 exhaust.....
i think thats some pretty respectable times for 2 too many doors!!!! hehehe
ps once again, dont power brake the auto, just hold your foot on the brake and then floor it, all at the same time. you should pull high 2.1s without even trying on the stock tires at full tire pressure....
Old Nov 5, 2005 | 10:40 PM
05-G35 Sedan 5AT
theres NO way that a stock sedan, here in Vegas, will run low to mid 14s... Maybe at sea level in Florida, but not in the high desert.
NOS is a different story, but thats not stock.. THere are a few Gs that run out here and 15s is a good average.
sorry but I would have to see that to believe it..
Old Nov 5, 2005 | 10:52 PM
go to the florida g35 section and ask anyone what i ran stock. i know i am in florida so stuff is different but i ran 14.2 witha 2.1 60 foot and finished at 95 mph. that was totally stock with the spare tire and jack out....
the main thing with the autos is not to powerbrake it off the line, it causes it to bog and you will get really bad 60 ft times....
Old Nov 5, 2005 | 10:55 PM
btw i have an 04 sedan. i leave it in 3 when i take off, that way it shifts into 2 and 3rd automatically, i hold out 3rd to 6800 and run 4th as far as i can....
Old Nov 5, 2005 | 11:09 PM
05-G35 Sedan 5AT
I power braked it a little bit but not enough to spin the tires, with the VDC off.. After I let off the brake I would get a little tire spin but no bog.. I was up against Sub WRX both runs the 2nd run was an Sti..
I took both off the line to about the 60' mark where the Sti began overtaking me. I beat the non-sti wrx on the 1st run. My 60' times are 2.3 seconds. THe WRXsti ran a 13.8..
I had a little over a 1/4 tank of gas, aprox 5 gallons @ 6lbs per gallon= 30lbs and the spare and jack were still in the car adding another 40 lbs..
Old Nov 5, 2005 | 11:52 PM
yeah, 2.3 60 ft times are really slow, not raggin on your takeoff at all, but you should be able to do much better. just hold that brake, set your right foot about 8 inches off the gas, when the tree hits that second yellow, slam your right foot down and let off your brake foot. it might spin a bit but you should pull at least low 2.2s and 2.1s on occasion....
the difference in 14.5 and 15.5 is about ten car lengths, you should def be able to do better...
Old Nov 5, 2005 | 11:57 PM
05-G35 Sedan 5AT
I will give it a try..
Im old school chevy man.. this new technology is.. well, new..
