HELP Changing the brakes
Old Nov 5, 2005 | 11:01 PM
breaz's Avatar
I have 03 sedan with sport suspension and non brembo brakes. I was trying to remove the rear rotors but failed misarably Is there a trick to removing? I want to turn the rotors so I can't beat them to death but I did try wack a few times and used some liquid wrench around the studs and the hub to loosen any rust. Has anyone done this on the 03 sucessfully? Any tips??
Old Nov 5, 2005 | 11:14 PM
D87's Avatar
D87
https://g35driver.com/forums/brakes-suspension-diy/52272-diy-5at-brakes-rotors-diy-oh-my.html
Go to the Do It Yourself Forum - or do a search. Good luck!
Old Nov 6, 2005 | 08:08 AM
Dudefish's Avatar
I believe if you have the parking brake set you will not be able to remove the rotor.
Old Nov 6, 2005 | 09:24 AM
breaz's Avatar
No parking brake! I wish.
Old Nov 6, 2005 | 09:26 AM
breaz's Avatar
I saw that post and tried that too. How hard can I hit the rotors without damaging them? I don't want to take it to the dealer or meineke!!!!!
11bEMT
May 27, 2022 03:13 PM
linedr89
Aug 17, 2015 05:11 PM
miata007
Aug 17, 2015 04:36 PM
kinetek
Aug 3, 2015 04:25 PM
sahizzle110
Jul 29, 2015 11:36 AM
