Calling all G's
Old Nov 28, 2005 | 09:57 PM
g2max's Avatar
Calling all G's
My buddy sent me this link for a salvaged/repairable 04 g35x for $14,500. DO you guys even think this is worh entertaining?
http://www.alsautopa.com/Rebuildable...7&V=14&R=2&M=0
Old Nov 28, 2005 | 10:05 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
You would not believe how much it takes to replace air bags (including seat)
JMHO,...This falls into the category "if it sounds to good to be true......"
edit..
they only list 2 bags deployed;
4 are deployed seats & side curtain on each side
Old Nov 28, 2005 | 11:17 PM
G35Papa's Avatar
The driver's side doors are out of alignment and the driver's side rear wheel looks like its angled in. Based on that I bet the frame got a nice bend to it.
Not worth it. Its going to cost you alot to get it fixed right and even then it still probably won't be "right"
Old Nov 28, 2005 | 11:22 PM
JDM 350GT's Avatar
yeah...frame damage is a killer.
good luck tho...
Old Nov 29, 2005 | 11:02 AM
jawjaw's Avatar
I seriously doubt that is worth the trouble. Like the others said, parts and repairs are very expensive. Someone is trying to make money on the car so you know they are not just giving it away. If you do your research by figuring out what needs to be done to the car, how much it costs to fix, and then do the math, it should be obvious if it's a good deal. You also need to factor in that the resell value will be garbage since it's been in a nasty wreck.
Old Nov 29, 2005 | 12:04 PM
wanalaugh74's Avatar
I have had a few buddies that had "rebuilds" from salvages and they are never "right" again.
Old Nov 29, 2005 | 12:50 PM
shodog's Avatar
That car got smacked harder than it looks. Really this car is only worth it's parts that are reusable. Although there is an asian body shop by my house that would fix it up. you should see some of the stuff they can fix.
Old Nov 29, 2005 | 12:56 PM
da mayor's Avatar
salvaged cars are only worth it for a show car not to be driven for safety concerns
Old Nov 30, 2005 | 02:23 PM
yassy's Avatar
not only the frame. look at that engine! did someone take a **** all over it?
(that would be a lot of ****(#&)&$(&$)
prinny
Nov 22, 2015 11:07 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
