Wheel spacers
Old Dec 30, 2005 | 03:46 PM
VQ Hotness's Avatar
Wheel spacers
I just got some half inch wheel spacers witch comes out to be about 12 or 13 mm.. Do you guys think i will need new studs??
Old Dec 31, 2005 | 01:13 AM
VQ Hotness's Avatar
CAn anyone Help
Old Dec 31, 2005 | 10:33 AM
Gsedan35's Avatar
Even with 5mm spacers you end up needing longer studs, so the answer is yes. I had the 5mm H&R spacers and when I tried to install them I noticed that I could not get the required number of turn's to safely seat the lug nuts.
Are the spacers you have hub centric? And how much did they cost per pair? It would be interesting to see pics of them.
Old Dec 31, 2005 | 12:12 PM
VQ Hotness's Avatar
Not sure yet what they are , all I no is their around 13mm and they where like 6 bucks a peace. Does any one no any places besides ebay to get some reasonble 10mm spacers with the new studs in them? THanks
Old Dec 31, 2005 | 12:14 PM
VQ Hotness's Avatar
ANd why cant i find wheel spacers that are 10mm with new studs in them
Old Dec 31, 2005 | 11:23 PM
Gsedan35's Avatar
Here's a link (2nd line under "Nissan" is for 10mm spacers)
http://www.ltbmotorsport.com/nissan.html
Eibach
Pro-Spacer
Performance Wheel Spacers by Eibach
Made from High-Strength Aircraft-Aluminum Alloy
Precision Engineered Hub-Centric for Perfect Fit and Wheel Balance
Strength-Tested for All Applications
Extreme corrosion Protection Through DIN 50021 Approved Coating Process
TUV, QS9000 and ISO9001 Quality Approved
Reduced Weight Compared to Steel Wheel Spacers
jsimonk
Dec 22, 2023 03:49 PM
paolojericho11
Sep 11, 2015 07:08 AM
tphan
Aug 31, 2015 10:45 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
