Tire Pressure Monitoring System "BROKE"
Old Jan 3, 2006 | 02:29 AM
Tunerz_Store's Avatar
I have done some extensive searching, but couldn't find the definate answer I need. With Key On Engine Off, should or shouldn't the low tire pressure light be on? If so, my light doesn't come on. Is there something I can do to reset the system? The car is stock, just bought it a few days ago. Still has the Goodyear Tires w/20k on them. I'm sure I will probably have to take it back to the dealer. Just making sure I'm not over looking anything here. Thanks!
Old Jan 3, 2006 | 01:10 PM
jimmyc13's Avatar
Hmmm...good question. I don't recall it lighting up w/ the key on...don't have my car today @ work, so I can't help ya out. Worst case (if no one else answers), call the service dept.
Old Jan 3, 2006 | 04:48 PM
Msedanman's Avatar
O.F. Administrator
I don't remember either...but it should say in your handbook which of the lights come on, then go out with the key in the ON position.
If not, then the dealer should know.
If there is a problem with the system, I understand that he can re-initialize the system to make it right.
g/l
Colin
Old Jan 3, 2006 | 06:15 PM
sydg35's Avatar
the car comes with a manual for a reason...."the low pressure warning system will activate only when the vehicle is driven at speeds above 20 MPH. Also, this system may not detect a sudden drop in tire pressure." All manuals can be accessed throught the infiniti website under "ownership"
Old Jan 3, 2006 | 07:37 PM
kevink's Avatar
On my 2004, the Tire Monitor light goes on when I turn the key, along with the VDC Off light, then very quickly goes off.
Old Jan 3, 2006 | 08:52 PM
Andy77's Avatar
The manual, on page 2-9, says that that light, and several others, come on briefly when you turn the key to on. They do mean briefly. Enjoy the car!
Old Jan 3, 2006 | 09:50 PM
vegasG35sedan's Avatar
05-G35 Sedan 5AT
My 05 comes on for less than 2 seconds..
Old Jan 4, 2006 | 10:58 AM
jawjaw's Avatar
You could deflate a tire down to 20psi to know for sure whether they work. It doesn't take much of a drop for these things to go off.
Old Jan 4, 2006 | 03:48 PM
Andy77's Avatar
I finally remembered to check the light in person today. It stays on for 1-2 seconds as vegas said above. If you are not looking at the left lower side of the dashboard when you turn it to ON, you'll probably miss its short glow.
So what has been the outcome?
Old Jan 5, 2006 | 01:47 PM
perry05G35's Avatar
Hmm mines hasn't come on ever since I had a nail in one of my tires and had the tire replaced... Oh well I have new rims now but if I ever go back to stock I will remember that...
Old Jan 6, 2006 | 02:31 AM
I was looking in the wrong part of the cluster. It comes on, figured that out after I dropped one tire down below 25psi, then I heard the 10sec beep and noticed the light. It is all good. Thanks for the replies.
Old Apr 3, 2006 | 05:07 PM
Jeff92se's Avatar
Red Card Crew
Question. What if you don't run tps?
Old Apr 3, 2006 | 11:59 PM
woshiagni's Avatar
Not sure about other years, but on 05's with no TPMS in your wheels the warning light will come on about 45 minutes into your drive. IIRC, no audible signal which is A Good Thing.
Old Apr 4, 2006 | 12:05 PM
jimmyc13's Avatar
Same with my '04...only the light comes on...and after about the same amount of driving as you said. Once you turn your car off, it resets and will come on again after driving another 45 min. or so.
jsimonk
Dec 22, 2023 03:49 PM
RA102223
Aug 15, 2015 09:24 PM
TWASkyliner
Aug 1, 2015 11:43 AM
joedaddy1
Jul 28, 2015 02:58 PM
