rear view mirror and radar together
Old Jan 6, 2006 | 05:32 PM
rraabb11's Avatar
ok-heres the deal:
my car does not have the premium mirror
i will buy one
now...
i want to hardwire them both to the fuse box
im ok with that
question:
can i "y" off one power/ground wire for both the mirror and detector?
is a 3 amp fuse ok for both?
why does:
http://cgi.ebay.com/ebaymotors/Gente...temZ8020502858
do i need 2 power wires-one for homelink, one for auto dim
is it ok if they are always on?
(ill turn off detector when im done driving)
i just wanna knock out both wiring/make it clean install at the same time
ps-i dont want use the invisicord-not necessary
thanks for help-
rob
Old Jan 7, 2006 | 09:09 AM
rraabb11's Avatar
help
Old Jan 7, 2006 | 11:58 AM
G35_TX's Avatar
There is no wiring up in the roof that will shut off with the ignition. I had to wire my radar into a hot wire which is always on behind the map lights. The powersave on the car shuts my radar off after a short period so it doesn't pull on the battery.
So you will need to run the new wire from the fuse box up to the roof and into your new mirror. And yes you can split it. 3 amps is more than enough for both items.
Old Jan 7, 2006 | 12:42 PM
Nodnarb901's Avatar
On my 04, I wired it to the sunroof motor wire harness. powers off after the key is turned off and the door is opened. Took me about 45 min (most of which was probing wires to find which was 12v with ignition)
Old Jan 7, 2006 | 07:20 PM
rraabb11's Avatar
hmm
does my car have powersave too? or is that part of some other wiring? (audio equipment, etc.) couldnt i just do an add a circuit to the accessory fuse? (so it would shut off like the cig adapter in the arm rest?) what guage wire do you suggest? 18? (i think like the end of the add a circuit) i was just going to use phone line w the bel detector and splice it in...
mjfenix
Aug 17, 2017 05:49 AM
carid
Group Buys-Vendor
Aug 7, 2015 12:17 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
