Dyno today. Are these #'s right?
Old Jan 19, 2006 | 04:45 PM
  #31
Mario77746's Avatar
Originally Posted by G35_TX
IMHO, I would reset the ECU. It might be acting a little funny.
Good idea. I'll try it over the weekend to see if my MPG increases.
Old Jan 19, 2006 | 05:06 PM
  #32
DaveB's Avatar
If you think it's rich now, wait and see what a reset will do Think about it for a second, reseting the ECU results in an ECU that must revert back to a safe preset fuel map. This safe fuel map will be very rich because Nissan doesn't want you to blow the engine if you were driving in an oxygen rich/dense environment. As you continue to drive, the ECU will start adjusting the A/F ratios and timing to be more aggressive and match the conditions the engine is run in. At WOT there will be very little difference between a reset ECU and one that is not. Part throttle wise though, there will be a noticable difference. I notice about a 10-15% drop in MPGs and boggy part-throttle acceleration after an ECU reset. My 96 Maxima with the 3.0 VQ did the same exact thing.
Old Jan 19, 2006 | 05:08 PM
  #33
DaveB's Avatar
80% of the time the TRACK will not show problems with the car. Becasue it might still run good, but then all of a sudden it could just blow up. The Dyno A/F will show a problem if the reading is correct. And if this is correct, something isn't right.
I see what you're saying, but in his case, the car is supposedly running really rich. He ain't gonna blow anything up. Rich doesn't blow up motors. Lean conditions take care of that.
Old Jan 19, 2006 | 05:18 PM
  #34
mistermojorizin's Avatar
so why do they tell you to reset after a mod?
Old Jan 19, 2006 | 06:40 PM
  #35
G35_TX's Avatar
Ok and what data do you have backing this? NONE!
I gain MPG when I reset my ecu. And everyone else I know gains 1-2 mpg.
A ECU reset will get rid of any parameters the ECU learned that may be causing your rich issue. Just RESET it and be done with it. Either way it won't hurt.
Old Jan 19, 2006 | 06:41 PM
  #36
G35_TX's Avatar
Blowing up a engine was a example not related to his problem.
Agggg, wasted 10 sec of my time again on DaveB. I am outta here.
Old Jan 19, 2006 | 08:36 PM
  #37
Mario77746's Avatar
Well, for the hell of it I'll reset it over the weekend and put a end to this debate. I have been resetting my trip meter at each fill so I'll log what I get for this current tank and post what I get for the next tank with a reset ECU. It will probably be in a week.
Later...
Old Jan 19, 2006 | 11:17 PM
  #38
DaveB's Avatar
Get over yourself, Russ. I not trying to start something with you.
My data is what I see on a data logger and my calculated mpgs.
Old Jan 25, 2006 | 08:15 PM
  #39
Mario77746's Avatar
Filled up with exactly 18 gallons after work. I went 287 miles, roughly 16 miles per gallon. I'll reset the trip meter tonight, do a battery disconnect and see what the next tank gives me.
Later.
Old Feb 3, 2006 | 11:04 PM
  #40
Mario77746's Avatar
Filled up with 18 gallons again after the reset. I went 280 miles on that tank also.
Old Feb 3, 2006 | 11:47 PM
  #41
DaveB's Avatar
How can this be!!!! The ECU reset didn't improve gas mileage? Impossible
Old Feb 4, 2006 | 01:25 AM
  #42
G35_TX's Avatar
Strange. I just put 17 gallons and went 370 miles on this tank.
lol
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
G35xdriver04
Nov 7, 2015 08:31 PM
itgogitrev
Sep 23, 2015 07:08 PM
