05 headlight question
Old Jan 15, 2006 | 07:55 AM
stnwag0n's Avatar
When I first bought my 05 sedan, only the top part of the headlight (HID) would come on when turned them on. I noticed that on 03-04's, the top (HID) part and the bottom (halogen) would both be lit. Recently, my bottom halogen part started to come on along with the HID, and is always on when I turn the headlights on. I made no changes to the car at all. It just happened. I thought the lowers might be foglights, but I cant find anywhere in the manual how to turn on/off foglights. There is no loss in functionality or drivability, but I kinda want it back to the way it used to be. Anyone else have this problem, or know how to solve it? Im sure its going to be something really easy but I just cant figure it out.
help please
Old Jan 15, 2006 | 08:08 AM
chinee's Avatar
The lower half (halogen) is the foglight. There a separate switch on the stalk to switch it off. It should be mentioned in your manual, or just bend your neck a little and read the stalk... you'll find it easily.
Old Jan 15, 2006 | 02:14 PM
basus's Avatar
When i switch on the foglights its exactly the same as the headlight, whats the difference
Old Jan 15, 2006 | 04:52 PM
RetAF's Avatar
Wink
The fogs and the high beams are in the same bulb. In lesser cars than the G, what is our fog light is their low beam! Don`t question inscrutable Asian logic. Accept it and be proud!
Old Jan 15, 2006 | 10:46 PM
g35guy86's Avatar
Do you have HIDs on your G because if you dont then there isnt going to be a difference.
Old Jan 15, 2006 | 10:51 PM
Buzzman's Avatar
just remember to check your headlight fluid...sometimes that dims it down
Old Jan 15, 2006 | 11:57 PM
perry05G35's Avatar
All 05 G35s came with HID it's standard.
Old Jan 16, 2006 | 01:07 AM
LuXXXz's Avatar
you have the foglight on
Old Jan 16, 2006 | 06:13 AM
stnwag0n's Avatar
my headlight fluid was low. thanks
[i found the foglight switch on the stalk. thanks for reals guys.]
Old Jan 16, 2006 | 08:48 PM
LuXXXz's Avatar
lol^
only use dot 3 fluid
Jusseth
Sep 13, 2020 12:25 PM
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
bTanz
Oct 15, 2015 02:31 PM
as25656800
Aug 9, 2015 07:25 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
