I'm looking at a set of wheels in these widths with +35 offsets both front and rear. Anyone have any input? Too much tuck? Rubbing?
Anyone running a 10" out back?
Thanks!
Thanks!
Wow good question you will not have any problems in the front for sure as far as the back is concerned a lot of people have +45 with a 9.5 wheel so +35 on a 10" wheel SEEMS like it will stick out. Might want to ask in the wheel and tire section...
Modded Member
Do not even try to run that combo. It will look like an old school Cadillac lowrider, and the rubbing will be unbearable.
Quote:
And that's not what I want?Originally Posted by vodkarocket
Just kidding. That's about what I thought.
There are a couple of guys that shoe horned 10" wide wheels in the rear. You'd have to have an offset of around +55. But what's the point? Is another 1/2" going to make that much of a difference in the rear?
Quote:
It's not going to make a difference. I just ran across a deal here locally.Originally Posted by skeleton_cru
Is a 275 width the widest you can fit under the rear of the sedan? How about 295 like some of the Z's run?
I was gonna go with 10's in the back and I heard a lot of issues with that fit. Just go with a 9.5 in the rear unless you dont mind rolling or cutting your rear fenders.
Modded Member
Quote:
Haven't seen 295 yet, but one person has stuffed 285's on his sedan- this was also due in part to a perfectly selected offset.Originally Posted by MardiGrasMax
