View Poll Results: Eibach pro-kit or Tein 350z h-tech for 2003 g35 sedan
pro-kit
33.33%
350z h-techs
14
66.67%
Voters: 21. You may not vote on this poll
eibach pro kit vs. tein 350z h-techs...
Old Jan 17, 2006 | 01:01 PM
wilboytsk's Avatar
Scenario...
2003 g35 sedan...17" wheels...non sport suspension...
2 kids...daily driver for work...occasionally pack the family in when suv needs a rest...
not looking for a drastic drop and losing any ride comfort....about 1 inch drop pref....eventually going with the factory 19" coupe wheels within the next month or so.
Needing input on the best springs without going with any camber kits or upgraded shocks.
I've went through the searches and found pros and cons on the prokit and 350z h-techs...
Help???
Old Jan 18, 2006 | 04:12 PM
wilboytsk's Avatar
bump
Old Jan 18, 2006 | 05:44 PM
shodog's Avatar
the Eibach pro kit is made for the sedan which will give you about a 1" drop the 350z h techs will lower and already lower 350Z which will be way too low for the sedan. You would be better off buying someones old 350Z springs.
Keep in mind your non sport shocks and struts will never hold up to the higher spring rate of either spring you mention.
Old Jan 18, 2006 | 10:13 PM
QuadCam's Avatar
I have the 350Z h-techs. They are lower than I expected. all the expert suspension posts list the drop as 1.3/1.2" For soem reason, the rear is pretty low. The stock 235/45-18 tires sat flush with the fender opening. Too low IMO.
Also, the 350Z H-techs seem to make the car have alot of power oversteer.
It is good for the drift-racer in all of us though.
Old Jan 18, 2006 | 11:54 PM
wilboytsk's Avatar
Thanks Shodog and Quad for the info...what do you guys think of the 350z springs and shock set up for an 03 sedan? and what year do you guys recommend? Can someone post some pics of this set up..good lookin out!!!
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
reavensf
Sep 17, 2015 11:30 PM
NohoG35revup
Aug 22, 2015 12:13 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
