Can Someone Please Help With a DIY of Removing the Power Duct
Old Jan 23, 2006 | 09:09 PM
stl_ls1gto's Avatar
I would think that by the looks of your air filter, just changing to a new paper filter would give you some gains....its pretty dirty man - ever change it? or is it still the factory one....just wondering.
Old Jan 24, 2006 | 02:05 AM
aequitask's Avatar
its the factory one...i only have 7800 miles on it...when should i change it? maybe ill get the k&n one soon
Old Jan 24, 2006 | 08:48 AM
G35_TX's Avatar
Originally Posted by andy2434
Soooo, can you either hear or feel a difference? I had removed the power duct, as well. After a day without it, I put it back. I could not hear nor feel a difference, so I figured why suck up the additional heat from under the hood.
Heat is no good. Leave the duct on. It gains nothig.
Old Jan 24, 2006 | 11:36 AM
DaveB's Avatar
See post #12.
Old Jan 24, 2006 | 12:32 PM
G35_TX's Avatar
Originally Posted by DaveB
See post #12.
Quote:
I've done data logs of the air intake temp and I see about ~10 degree higher intake temps at a stop. Once rolling, there's no difference. At the track, I was no slower. Actually, I ran better (14.32 vs 14.49), but I attribute the improvement strictly to better conditions.
10 degree higher temp at a stop takes away power. The hotter the intake temp, the less power you have. But you ran a better time only due to conditions not the intake.
Like I said, do not remove the duct. There is a reason its there. Remove it at your own risk of losing power.
Old Jan 24, 2006 | 12:41 PM
jimmyc13's Avatar
Originally Posted by aequitask
yea im prolly gonna put it back on...i didnt hear any real difference as well....i dunno why ppl said it sounded so good
That's because you don't have a Z-tube....with the stock tube and those two large resonators, they are robbing your sound from you! I still can't get over how much my car roars now @ WOT.....it's actually so loud now, I've been noticing some vibration @ WOT . Once I throw the HKS muffler on, I may put the duct back on.
Old Jan 24, 2006 | 01:45 PM
aequitask's Avatar
so i should take the resonators out then too? 05blk told me about that and he has it done to his car...should i do the same then?
Old Jan 24, 2006 | 03:51 PM
DaveB's Avatar
The point was I lost no power and I pulled 2.15 60 foot with the duct removed. If having the duct removed made my car feel less powerful, then I would have put it back on. I had GG wires for a week and they made no difference, so I took them off and sold them.
Old Jan 24, 2006 | 06:36 PM
jimmyc13's Avatar
I haven't read about people "taking them out", as they are attached to the tube; however, I have read of one member using exhaust patches and applying them on the interior of the tube....this closes off the two resonators port openings located within the tube. I myself am not knowledgeable in this, so I wouldn't know how to do it....I'd spend the $80 and buy the Z-tube if I wasn't sure. FYI - the 1st resonator is that plastic piece on the top (it's visible in the picture above...it's the flat plastic piece just above the flex boot). The 2nd one is on the lower part of the tube (I don't believe you can see it without taking the tube out)...but it's HUGE! (extends 6-8" down into the engine bay)...I couldn't believe it when I removed mine. Good luck.
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
RA081024
Sep 7, 2015 01:29 AM
Mick_L
Aug 25, 2015 04:27 PM
linedr89
Aug 17, 2015 05:11 PM
Kz_Ed
Jul 23, 2015 02:41 AM
