Side mirror removal
Old Jan 26, 2006 | 07:13 PM
Jeff92se's Avatar
Red Card Crew
Side mirror removal
I might have to take off my pass side mirror. I found this article here:
http://www.g-owners.com/article_read.asp?id=9
Do you really have to take off the interior side panel to remove the mirror? I haven't looked but it would see the mirror mounting bolts should be under the triangle cover above the door panel. Can't I just pry off the interior triangle piece and unbolt the mirror assembly from there?
Thanks
Old Jan 26, 2006 | 09:13 PM
DaveB's Avatar
Thanks
I don't think so. Anyways, I've removed my door panels to fix rattles/squeaks and it takes me all of 3 minutes to have the panel off and the door latch cables removed. It's cake.
Old Jan 27, 2006 | 11:26 AM
Jeff92se's Avatar
Red Card Crew
Thanks Dave. Maybe I should just pm you all my questions directly
Just got the Z tube in. Of course the tab for the support is broken No biggie as it's supported fine anyway. I have an extra 3" mandrel bent pipe here. With the stock couplers I could probably weld up a "Z-tube" pretty easy. The only reason I'd consider it as I could put the vent connection back on top.
Old Jan 27, 2006 | 11:28 AM
FenixL1P's Avatar
i've got clear bra ppf on my mirrors already so no go for me...i don't like the blinker's location on the mirror anyhow...i prefer the scion tc style... but i do need to replace my driverside mirror glass because for some odd reason, it got a small chip...i don't know from what but it is sorta distracting...
Old Jun 18, 2006 | 01:47 AM
inspector_yoo's Avatar
You do need the remove the door panel due to the wiring. The mirror itself is bolted on by 3 screws.
Old Jun 26, 2006 | 11:37 AM
gfolo19's Avatar
slightly off topic....to replace your mirro housing and all is 500$ from the dealer....shop around find the glass and do it your self, you have to get the housinf from the dealer but dont let them install it and you might want someoneelse to paint it cuz they charge rediculously for painting...
Old Jun 26, 2006 | 11:48 AM
Jeff92se's Avatar
Red Card Crew
Yup. I grabbed a whole assembly from ebay. I haven't got around to doing this yet. I'm debating getting the lowers painted at the same time.
Old Jun 26, 2006 | 01:34 PM
RocketG35's Avatar
Why do I bother to DIY???
Speaking of mirrors...would it be possible to fit the Coupe/Z mirror on the Sedan? I assume the A-pillar angle would be different, but is this a possible mod? I like the sharp edged shape of those mirrors better than our rounded one. I haven't looked into this too much, but its a mod I'd really consider doing if it its possible.
Danielek
Aug 11, 2015 09:33 AM
Nick_M
Aug 3, 2015 11:08 PM
.cakestar
Audio/Video/Electronics
Jul 17, 2015 08:22 PM
emorehs
Jul 17, 2015 09:45 AM
