5AT shifter, is it possible to change the knob?
i have an 03.5 sedan, and I HATE the way the shifter looks. if i cant change the ****, i would at least like to see if i can throw a boot on there to cover bare metal, it looks like the whole circle thing comes off, and it has somthing called a shift lock. what the hell is that, does that mean i can take it off and add a boot? anybody....?
you can change the ****. just shift into drive and push the silver piece down right around the neck of the shift (you might have to use your nails to get it lose) then there is a little ring that is shaped like a "U" and that should just pop off in the direction of the radio. Then the **** should just pull off. not sure about shift boots.
+1 for MOMO shifter. get it here:
http://performancenissanparts.com/ca...roducts_id=331
i have had it for a few months, and it's *very* nice. the only bad thing about it is mounting it centered is a bit of a PIA - it takes a few tries to get it perfect.
FS[SoEast]: 2006 DG Coupe Part Out - mrev2, projectors, etc
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
BasquiatPicasso
Jul 23, 2015 06:26 PM
