Problem with the window going up and down.
I'm having the same problem with the front passenger window which I'm currently trying to resolve. Does anyone know if the wood trim piece from the grip handle have to come off to fully remove the door layer in order to get to the door actuator and window reset switch?
Well I finally was able to fix the window problem this morning. Took me 20-25 min. The only tricky part was removing the wood trim grip finisher without nicking or scratching the trim. After that it was just a matter of pulling the door finisher from the body panel, and the reset switch is in a small hole on the door. The overall repair wasn't too bad at all
I'm not sure what you used, but I started using old credit cards/IDs to get under trim pieces and pull them off. It works pretty good and since it's a soft flexible plastic, I don't have to worry about scratching anything. I admit it is harder than using a screw driver, putty knife, or whatever, but I feel safer using them
^ I used an untaped flathead to get under the trim piece. Yeah it was more risky that way so I was careful enough not to scratch the trim. Good thing I D/L'ed the service manual for removing the door finisher and used that as a guidance
Originally Posted by G35r1d3h
But how can I reset the motor. I found this, but it's said for the coupe only. I tried it and it didn't work.
Here is the link
http://infinitihelp.com/Ownership/Bu.../ITB04-033.htm
Here is the link
All G'd Up
Aug 29, 2015 12:40 AM
