Problem with the window going up and down.
My passenger side window is giving me a problem this past week. Whenever I press the auto button it goes all the way up, but comes down again half way. But if I do it manualy it works perfect, anyone have any idea why this will happen.
Auto-Up
But how can I reset the motor. I found this, but it's said for the coupe only. I tried it and it didn't work.
Here is the link
http://infinitihelp.com/Ownership/Bu.../ITB04-033.htm
Here is the link
Problem fixed by resetting the actuator
Procdure is as follows:
Roll the window up
Then hold the reset button while rolling the windows down (not using auto)
Release the reset button when it reaches the botton and roll back up (not using auto).
Roll the window up
wow kwiniarz thanks for bumping this old thread i never saw it before. IT WORKED for me !!
thanks alot man i appreciate it the passenger window has annoyed the hell outta me. but it was dumb of me for jumping outside at midnight trying to do this in my apartment parking lot. the security guard saw someone in my car and came over to check what was going on. i also took apart the entire aluminum door to get to the inside. all i had to do was peel back that damn sticker ! owell well worth it for me it has been such an annoyance for the last 6 months.
I have this same exact problem only its on my driver side window. I would like to try the following procedure below, however, what and where is the actuator?
Roll the window up
Roll the window up
has anyone had a problem when it just rolls down by itself in the middle of the night? I have came out to the car and the pass window is the only one that is rolled down? From what I have notice it only happens sometimes when it rains. Help me please.
Originally Posted by bull3t
i have this same problem...im gonna give it a try tomorrow
i just finished fixing it...it worked like a charm...when you guys do it, remember to make sure you unplug the puddle light and to take out the screw behind the aluminum door handle bar...the actual reset button is behind a black leather looking sticker around the gold bolts...those were the only areas you guys might get stuck on...it's very easy to do...
