Manumatic question. Did not function
Old Feb 13, 2006 | 03:50 PM
Jeff92se's Avatar
Red Card Crew
I was driving (normally I might add). And decided to play with the manumatic mode. But when I did, the display didn't show "4" like normal. Stayed in "D". And moving the shifter up/down did nothing. Happend the entire time I was driving. Even when stopped at a light. 1 hour later (after turning off/on the car I suspect), the manumatic mode returned to normal.
Normal? Explaination that's well known?
Old Feb 13, 2006 | 04:11 PM
cato's Avatar
SouthernComfort Moderator
Drop the crack pipe!
Jeff92se's Avatar
Red Card Crew
And then?
Old Feb 13, 2006 | 04:59 PM
GeeWillikers's Avatar
Walking The Fine Line...
Sounds like an electronic blip.
If no ill effects remain, I wouldn't sweat it. If all is well and it hasn't repeated itself, no problem.
I've had no problems with manual mode, although I get a hard (read firm) shift from 2-3 every now and then - only when I'm flogging it.
Old Feb 13, 2006 | 05:32 PM
aequitask's Avatar
the hard 2-3 shift happens usually when you first start driving..thats what ive noticed but it goes away after a minute or two...and i ALWAYS drive in manumatic (shouldve got stick)
Old Feb 14, 2006 | 03:37 PM
Jtrain's Avatar
^ I hear that, I like being able to have auto when i want it tho...
Is there a reason taht when your cruising in 5th and knock it over to manu, that it downshifts to fourth... i've never understood that
Old Feb 14, 2006 | 03:41 PM
Godfather's Avatar
it will always be in the fourth gear when you switch to mm mode. thats the default gear to start from. Althought what i wanted was, when i start to car and put it in the mm, i wanted the gear to be one instead of four.
Old Feb 14, 2006 | 03:53 PM
Jeff92se's Avatar
Red Card Crew
If you are at a standstill and you switch to MM, the tranny will go into 1st. But the display will show 4. Actually the tranny will go into 1st either way. But in MM, it won't every shift into 5th (overdrive)
I like the fact that if you switch to MM, it goes into 4th (ie.. on the freeway). It saves me time to do something I'd already do anyway.
Old Feb 14, 2006 | 05:56 PM
B GrAzi's Avatar
my car is always at 1 when i shift it over from a standstill...what year is your car?
Old Feb 14, 2006 | 05:57 PM
Jeff92se's Avatar
Red Card Crew
The tranny is in "1st" or the the display shows "1"? I have a 2003 auto. I can make it show "1" but I'll have to downshift 3 times and it won't go out of 1st until I tell it to
Old Feb 14, 2006 | 06:32 PM
EZZ's Avatar
EZZ
For 2002-2004, the autos in the sedans and coupes differed. The manumatic was functionally a top gear selector, you select the gear you want and the auto will go to that gear and stop shifting. For 2004.5 and beyond, the sedans received the same manumatic software as the coupe and functionally, it was a true manual mode automatic, whatever gear the display read was the gear you were in.
Old Feb 14, 2006 | 06:34 PM
mhollinger's Avatar
The 2005/06 Automatic transmission behaves differently from the 2003/04s due to a different software algorithm.
In my car (a 2005), when I shift to MM, the transmission can shift DOWN automatically, but will not shift up. For example, when in "D" it will shift down to 1 when I roll to a stop. However, if I were to stomp on the gas, the car would approach redline, and remain in 1st gear until I popped it up to 2nd. When in 5th gear, it will shift down, but will prevent you from downshifting to an unsafe gear (for example you can't shift down from 5th to 1st while at 80mph).
Does that clarify things? it works much more like an sequential-manual gearbox than the 2003/04's.
Old Feb 14, 2006 | 06:54 PM
Jeff92se's Avatar
Red Card Crew
Thanks but IMHO it's a display diff. As far as I know, if I to MM at a light, the display will show "4". But the tranny will actually (I assume) go into 1st gear. Then it will automatically shift until it reaches 4th, where it will stay until I shift up. It will act like a normal 4 sp auto vs 5 sp auto.
Looks like the 04+ autos will auto shift down into 1st at a light (MM mode) and stay there until told to shift up. Cool. What happens if you are going let's say 40mph and shift into MM?
Can this program be flashed into the older models?
Old Feb 14, 2006 | 07:14 PM
EZZ's Avatar
EZZ
Its not just a different display. Its an entirely different ECU and its not compatible with the new models. In the 04+ models, if you hit upshift before its ready to shift, it won't do anything. The display won't go up...just stay in the gear. As someone stated early, a true sequential gear shift rather than a top gear selector.
Old Feb 14, 2006 | 07:39 PM
mhollinger's Avatar
This isn't a different display. Its a fundamentally different logic for the transmission. Re-read what I said.
