what do you guys think of this?
Old Feb 21, 2006 | 04:57 PM
bert039's Avatar
I might use these for a HID retrofit. Do you have any personal experience with these knock-offs regarding any parts melting?
Old Feb 21, 2006 | 11:35 PM
araBONE's Avatar
^^anybody???
Old Feb 22, 2006 | 01:58 AM
soad's Avatar
i thought that the 03/04 headlights are not the same *** the 05/06 headlights . so if thats the case these will not fit the 05/06 sedans
Old Feb 22, 2006 | 09:28 AM
jaspergtr's Avatar
ahhhh, you're looking at putting your hid assembly inside of these housings, so you get the clear blinker, and blacked out housing? sounds like a great idea.... except for the possible melting aspect. let me know how it works out.
Old Feb 22, 2006 | 09:58 AM
mark5's Avatar
it said NO hid's with this housing
Old Feb 22, 2006 | 10:00 AM
jaspergtr's Avatar
does that mean you can't use them?
or it doesn't come with them?
Old Feb 22, 2006 | 10:02 AM
jaspergtr's Avatar
nevermind... i reread the item description...
it clearly states that the manufacturer does not recommend using hid bulbs with this housing... oh well...
Old Feb 22, 2006 | 01:41 PM
bert039's Avatar
Ok crazy idea, but I was going to use the black housing for the retrofit, so I wouldn't have any downtime with my stock lights. But when everything is said and done couldn't I just swap clear lens from my OEM onto the imitation and avoid the whole melting issue?
I'll let you guys know how it goes, I'm just going to pull the trigger and do this.
Old Feb 22, 2006 | 02:06 PM
jaspergtr's Avatar
i'm confused...
Old Feb 22, 2006 | 02:17 PM
BigSash's Avatar
this thread is retarded
Old Feb 27, 2006 | 04:49 PM
ttrank's Avatar
Grocery getter
Originally Posted by jasperg35
i don't mean to hijack, but, could you please post a pic?
i've been contemplating this route vs. clearcorners headlight housing. truthfully, it's because i'm afraid about the whole opening the housing, and resealing it myself. and i also want the clear blinker as well... but $1k? it's a bit much.
These are poor quality pics but can give you some idea. They are the only ones I have with me. The first was taken with my phone and the second was durring the day. No picture will show you how bright these are in person. They are soooooo cool.
Attached Thumbnails what do you guys think of this?-594216906_orig.jpg   what do you guys think of this?-dsc06091.jpg
Old Feb 28, 2006 | 09:29 PM
jaspergtr's Avatar
ttrank - those eyes are crazy!
Old Mar 1, 2006 | 02:00 AM
ttrank's Avatar
Grocery getter
Thanks
In person they don't have all that reflection like in the picture but they are that bright. The just look like four super bright white rings. I get so many comments from random people.
Old Mar 1, 2006 | 01:04 PM
BigSash's Avatar
ttrank: glad to hear you did the install yourself.
how did it go?
every1 is scared to heat their headlight housing to open it, everyone worries they wont get the seal right and moisture will get trapped,
how did you find that process?
do you have HIDs?
Old Mar 1, 2006 | 01:24 PM
  #30
ttrank's Avatar
Grocery getter
how did it go?
do you have HIDs?
All in all the install was not that bad. It took a lot of time, but that is my fault for trying to be super perfect. Heating the housings was not a problem at all. I was more worried about the 3M headlight protectors I have than the headlight but both came out fine. I even took one apart twice.
I did them for 12 minutes at 200 degrees then used flat head screwdrivers and a razor blade to keep the glue in place. It was not hard at all.
The kit comes with krazy glue to hold them in place. DO NOT USE IT, I tried it on the first one and put it back together. When the headlight was on the car the temperature change flexes the headlight but the halo could not flex because it was glued in place so they both broke. The next time around I just used a small amount of clear silicone to hold them in the center and made sure it had plenty of flex. They have not had a problem since.
The other issue is power. The inverters they come with are not very strong. So you need to make sure your wires (all of them, halos, +12 and GND) are as short as possible or they can be dim. I made the wires as short as I could as well as adding an independent power relay off the battery, using the parking lights as a switch and upgraded the ground to them. They have worked perfectly since.
I have a friend here at work with an 03' G that just got a set. I am going to help him do his too. They are a bit of work but once they are done they are soooooo cool! The best mods always take some time.
Oh, and yes I have HID's with 8000K bulbs. The stock bulbs are about the color of the halos. The 8000K ones make the halos look yellow.
The first pic is with stock HID's and the second is with the 8000K
Attached Thumbnails what do you guys think of this?-dsc06094_small.jpg   what do you guys think of this?-dsc06095_small.jpg
