Got an alignment today
Old Feb 15, 2006 | 05:19 PM
Tunerz_Store's Avatar
Well after putting the Z & coupe springs on about 2 weeks ago, I decided it was time to check out the alignment specs:
Aligned with 04 Coupe specs 17" wheels:
Left Front:
Camber Before: -1.07 degrees (specified range -1.25 - 0.25 degrees)
Caster Before: 8.03 degrees (specified range 7.42 - 8.92 degrees)
Toe Before: -0.09 degrees (specified range 0.00 - 0.08 degress)
Right Front:
Camber Before: -.99 degrees
Caster Before: 8.84 degrees
Toe Before: -0.10 degrees
Left Front:
Camber After: -.1.10 degrees
Caster After: no change
Toe After: 0.05 degrees
Right Front:
Camber After: -1.05 degrees
Toe After: 0.07 degrees
TOTAL TOE FRONT:
Before: -0.19 degrees (specified range 0.00 - 0.16 degrees)
After: 0.12 degrees
Left Rear:
Camber Before: -1.38 degrees (specified range -1.75 - -0.75)
Toe Before: 0.28 degrees (specified range 0.00 - 0.22)
Right Rear:
Camber Before: -1.11 degrees
Toe Before: 0.16 degrees
Left Rear:
Camber After: -1.48 degrees
Toe After: 0.16 degrees
Right Rear:
Camber AFter: -1.13 degrees
Toe After: 0.17 degrees
TOTAL TOE REAR:
Before: 0.44 degrees (specified range 0.00 - 0.44 degrees)
After: 0.33
So with all that said, they only part of the alignment that was jacked after the spring install was toe front and rear and toe left rear.
I was quite surprised at the outcome. Hope this helps anybody else in the future for this setup.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
jeffbdye
Jun 1, 2018 03:51 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
