Noooo !!!!
Old Feb 25, 2006 | 01:40 AM
irteza's Avatar
Noooo !!!!
So my g35 is making some noise. im pretty sure its coming from the right side by the tire. when im driving slow like 20-30 mph i hear a noise that sounds like something is stuck on my tire and as it rotates and hits that spot it makes the faint noise. (i checked the tires, thinking their might be a nail stick in it and that might have caused the noise but it turns out that there was no nail/screw or anything on the tires) but then today i was racing an acura TL and when i hit about 90+mph the passenger side wheel started shaking/vibrating. what the heck can this be? im so sad about it anyone had the same problem? ive hit 130mph on the g35 before and it never used to have this problem. (mind you i only go over 80mph rarely)
I would also like to add how much I love all of you. I recently got my g35 and have read tons of posts that helped me alot. thank you all for the support.
Old Feb 25, 2006 | 02:01 AM
drunkin master's Avatar
I would take the car into the dealer. That is def. a problem. Do you have stock or aftermarket wheels and or tires?
I would check to make sure that all the bolts are tight.
Good luck. let us know what is was
Old Feb 25, 2006 | 02:31 AM
perry05G35's Avatar
You are living ont he edge I wouldn't be racing cars if I had doubts about the health of my tires @ 90mph... Could be that you have a rock in your rotor and loss a wheel weight at the same time! J/K it's most likely a nail in the tire but not visable since you drove it through the steel belting by now.
Old Feb 25, 2006 | 06:59 AM
jimmyc13's Avatar
Yeah man....I really wouldn't be driving that fast if you have tires issues..... As for your tire problem....as Perry says...sounds like something is in your tire. Did you take your tire off the car to inspect it?...that's truly the best way to find a nail/screw. Good luck.
Old Feb 26, 2006 | 01:16 AM
BigSash's Avatar
how do you take off a tire?
j/k
SAKEN3.5
Southern California
30
May 1, 2008 05:40 PM
