Garage remote-no more visor
Old Aug 12, 2006 | 12:13 AM
sliderg35's Avatar
Originally Posted by Cobra-2-G
That high beam sounds cool.
I have homelink/sunroof/dual power seats/xenon headlights, 17' rims, etc.
but no NAV, heated seats, or ground effects kit. Is that not in the PP on an 03? I haven't really looked into it.
You're getting confused with the Aero and Sports packages. "Premium" package applies to the "inside" of the car only.
Old Aug 12, 2006 | 12:44 AM
ABQ_G35's Avatar
Well, the HID lights aren't the inside, they were part of the premium in '03 if I remember correctly.
Old Aug 16, 2006 | 11:56 PM
phatkiddx2's Avatar
how do i make my garage door opens when i flash the high beems?
Old Aug 17, 2006 | 11:11 AM
sliderg35's Avatar
OK, I let one slip by... "Most" are inside.
Old Aug 17, 2006 | 04:34 PM
jawjaw's Avatar
I put my garage door opener in the sunglass holder up above the rearview mirror. All I got to do is hit the bottom for the holder to drop, then hit the garage opener button. It fits in snug so it doesn't bang around while driving.
Old Aug 17, 2006 | 04:51 PM
G SEDAN's Avatar
my homelink has a longer range than my garage remote. It might be the position of the homelink, I don't know but I can open it as I pull into the street(6 houses away) vs. my remote, where I have to hit it about 2 houses away. It's better because I don't have to wait for the door to slowly open. by the time I pull into the driveway, the door is fully opened.
Old Aug 17, 2006 | 07:27 PM
harley01's Avatar
Bad news...the summer heat has caused the velco adhesive to melt and now the remote won't stick. Maybe I'll try the sunglass holder trick.
Old Aug 18, 2006 | 03:34 AM
HARLEY G35's Avatar
i have had my 05 since march of 05
and still can't get the homelink to work
any links that can help me more than the
car manual
Old Aug 18, 2006 | 12:55 PM
jimmyc13's Avatar
They actually sell a product that does this (different than what he described). It has a small reflector that you mount on the outside of your garage & wire it to your opener & when you flash your lights, the door opens. I personally don't like this, as that means, ANYONE can open your garage door...if you live in a shady neighborhood (luckily I don't), won't take too long for passers-by or neighbors to catch on!
Old Aug 18, 2006 | 02:13 PM
phatkiddx2's Avatar
I guess your right. However i do live in a good area but i still won't take that chance.
Old Aug 20, 2006 | 09:53 PM
Blackjack's Avatar
It's better to go with a more secure solution. I've thought about getting this one: Flash2Pass.
http://www.f2ptechnologies.com/f2p_consumer.php
Old Sep 30, 2006 | 11:08 AM
gnbtween's Avatar
car manual
I could not get mine to work with my old 350Z, but now I have it
working on my new G35.
My door opener is "rolling code" but old (1999)...so it takes two
people (or a rubber band) to get it programmed with HomeLink.
HomeLink programming w/older rolling code openers:
1. Have ladder ready (to reach door's "code" button)
2. Have second person in car
3. Park just outside garage, engine running
4. Close door w/remote
5. Clear HomeLink memory (see manual)
6. Program HomeLink w/remote (door will open)
7. Place ladder under door motor
8. Find door "code" button
9. Have second person press/hold Homelink button
10. At same time press/hold door "code" button til door's light blinks
11. Second person release HomeLink button
All Done.....Press/hold HomeLink button til door operates
If second person is not available, use rubber band w/ small wad of
masking tape to keep HomeLink button pressed in step "9"
We love our G!
Old Nov 23, 2006 | 02:42 PM
zeta_msz_006's Avatar
Don't know about that, basically if anyone steals your car they'll also have a key to your house!! And with your vehicle registration, it wouldn't be too hard to find your house.
Old Nov 23, 2006 | 02:48 PM
driguez's Avatar
:edit: nvr mind
Old Nov 23, 2006 | 02:52 PM
  #30
G SEDAN's Avatar
well if someone steals your car (which is nearly impossible) then you'd have bigger problems if you had a remote or they see you have a homelink. I dont think they'll know that they can go to your house and flash highbeams to get in. And most of the time, car jackers will not dare to be cruising around and get caught with the car. They will drive it to a chop shop right away. They already commited grand theft auto, I'm sure they dont want to commit home invasion too and get caught for both...just my .02.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
Duffy25
Accessories
Oct 12, 2015 01:45 AM
