2005 G35X Air Filter Replacement?
Old Mar 15, 2006 | 05:38 PM
XcarGO's Avatar
Just what is the proper procedure for replacing the Engine Air Filter on the '05G35X?
All I could find in the DIY forum was for the coupe.
What I did was to undo the 4 clips (2 on top and 1 on each side) also I removed a bolt that holds the plenum to the fender.
Separating the Front and Rear sections of the plenum was a real pain.
I did not remove the flexible air hose. Would that make the job easier?
Thanks,
Old Mar 15, 2006 | 07:34 PM
Konsole's Avatar
How often does the filter need changing? Seems a little early to change a 2005's filter... ?
Old Mar 15, 2006 | 07:40 PM
rupdog326's Avatar
Out of many - one people
Thanks,
Coupe and sedan has the same engine compartment so the procedure should be the same. Good luck.
socalg35x
Jul 28, 2015 10:42 AM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
ClwMike
Jul 23, 2015 12:55 PM
vstypicals
Jul 20, 2015 10:55 PM
justgotg35
Jul 19, 2015 12:33 PM
