5AT Question
Old Mar 20, 2006 | 07:56 PM
UJWHITE2's Avatar
5AT Question
I have an 04 g35 sedan 5mt.
When I'm at a stop and i push the ****er into manual mode, it defaults to 4M. If i want to shift it manually from a stop, i have to click down to 1. Is this normal?? Thanks.
Old Mar 20, 2006 | 08:03 PM
GLuXuRy's Avatar
My 04 coupe 5AT does not do that... if im at a stop and move it to manual mode... it shows a 1 .... go to the dealer and have them fix it... good luck
Old Mar 20, 2006 | 08:09 PM
IQ9's Avatar
IQ9
The sedans have a different map than the coupes and Zs. It is normal as I have both with autos.(G sedan & Z33)
Old Mar 20, 2006 | 08:22 PM
MrCrazy's Avatar
I have an 04 sedan 5AT, and when I push it to manual mode (at a stop) it too goes to 1.
Now an 03 doggy door sedan... thats the one with a different transmission all together (03.5 and up does what mine does).
Old Mar 20, 2006 | 08:36 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Sedans only....
It was a mid year change in '04
'03 & early '04 are basically an upper gear limiter.
In MM if you are in 4th and at a stop it will shift auotmatically up to 4th.
Late '04s changed to the same setup as the coupe.
If in MM & stop, it will reset to 1st and stay there untill you shift. (the way it should be)
I hate having to tap, tap, tap ..to get back to 1st
Strangely Lexus still uses the old top gear limiter setup in the new IS350
Old Mar 20, 2006 | 08:46 PM
DP03's Avatar
05 sedan here, and not only will it automatically set itself to 1 when you stop, it will downshift to other appropriate gears as well. For example if you're in 4, and slow down to 15 miles an hour to make a turn into your community, it will shift to 2 or 3 depending on your speed. It's actually a very "smart" system. It downshifts when you're going to slow for a gear, but won't upshift until you tell it to. Works well.
Old Mar 20, 2006 | 09:18 PM
UJWHITE2's Avatar
Thanks for the replies. Is it simply a software update or something the dealer could take care of? Thanks.
Originally Posted by inTgr8r
Sedans only....
Old Mar 20, 2006 | 09:20 PM
InTgr8r's Avatar
No.. they changed the TCU
Old Mar 20, 2006 | 09:22 PM
Twilight35x's Avatar
I'm driving an 06 Toyota Avalon rental and it does the same thing.
Old Mar 20, 2006 | 11:06 PM
MrCrazy's Avatar
Sedans only....
That's probably right then. Mine would be the later of the '04s.
Old Mar 21, 2006 | 10:03 AM
ducati999's Avatar
Is this something that a dealer will do under warranty or is this a chargable service. My MM mode will not adjust either, really annoying!!!!
Old Mar 21, 2006 | 10:29 PM
InTgr8r's Avatar
No we're stuck with it...
The ECU was also changed at the same time.
Old Mar 21, 2006 | 10:54 PM
DaveB's Avatar
I've driven both systems and to my surprise, I actually like the earlier "top gear limiter" setup. I like the fact that I have total control of manual mode, even from a stop. I found it annoying that when you're in MM an 04.5 and above, it always requires you to do all the shifting from the stop. It seemed like a lot of work. I like the fact that with my 03 I click it over to MM at a stop and I can tell the tranny exactly what gear I want it to shift up too or I can hold any gear I want.
One thing I do like about the 04.5+ tranny is that it's very responsive. It rips off MM shifts, even the 1-2. A WOT 1-2 manual shift in my 03 is met with an annoying reduction in power as the car shifts into 2nd. I call it Torque Management (ie a system that reduces wear on a tranny under severe load). My friend's 03 sedan does the same thing. Oddly, when I let the tranny do it's own thing on the 1-2, it rips off the 1-2 shift. Sometimes it barks the tires. Weird.
Old Mar 22, 2006 | 09:22 AM
ducati999's Avatar
In MM mode what can you shift @ as far as RPM's. I have to shift, or at least hit the shifter @ around 6,100 rpm's to make sure I don't hit rev limiter. I really wish it was more responsive and would shift faster so I don't have to anticipate the shift. I have heard that a 10 wire grounding system will make it more responsive.
i
Miles
999
Old Mar 22, 2006 | 11:34 AM
InTgr8r's Avatar
Originally Posted by DaveB
I've driven both systems and to my surprise, I actually like the earlier "top gear limiter" setup. I like the fact that I have total control of manual mode, even from a stop. I found it annoying that when you're in MM an 04.5 and above, it always requires you to do all the shifting from the stop. It seemed like a lot of work. I like the fact that with my 03 I click it over to MM at a stop and I can tell the tranny exactly what gear I want it to shift up too or I can hold any gear I want. .....
I know what you mean Dave...
I also like limiting to 3rd gear when in stop & go city driving, and 4th when the limit is a little higher.
What I hate most though is when I want run through the gears....
when I come to a stop; if I was in 4th, then I have to shift, shift, shift to get back to 1st.
I think over all I'd prefer the 4.5+ version.
