5/16 MD Plenum Spacer Installed!
Old Mar 21, 2006 | 03:20 AM
Tunerz_Store's Avatar
Then install is fairly straight forward and the directions are very helpful. I was some what confused on whether to leave the guide pins in or take them out completely. That was easily cleared up with a call to Tony. They come out! Replaced with provided bolts. ECU reset was completed, although I got different flashing sequences of the CEL. Directions state the light will flash rapidly first then will flash slowly to indicate a reset. Mine flashed the opposite, so I assume it was a typo. After getting everything installed and resetting the ECU, I fired her up. Maybe a slight difference in sound at idle coming from the plenum. Didn't really notice much difference at wide open throttle, mainly due to the Pop Charger screaming sweet nothings in my ear. The car seemed more responsive and had more pull, especially in 2nd gear. She chirped all 3 gears and damn near got 4th during a test drive. I also got the opportunity to spank this NA z32 with ungodly exhaust from a dig during this said test drive (BUS LENGTHS), but that was just an added bonus. The car seems to have gotten that little bit of low end power lost with the Pop Charger. I was going to reinstall the oem airbox w/k&n, but the spacer compliments the pop charger. This is well designed product and you get very good customer service to boot. You can't ask for more out of any product you buy. Just one reminder, make sure you use a inch/lb torque wrench. Most have no clue how little torque is involved with 30-60-90in/lbs. You use a normal 3/8 ratchet and you will be sure to strip a bolt. If you don't have access or can't afford one, use the screwer driver/socket setup. Most can't torque more than 90in/lbs. I hope this post clears up any doubts about the spacer.
Old Mar 21, 2006 | 07:22 AM
Philly_G35's Avatar
Sounds great. I just got mine in the mail yesterday. Hopefully I won't have to work again this weekend so I can do the install.
Old Mar 21, 2006 | 09:58 AM
ducati999's Avatar
hey philly I was waiting for someone to get this done to a 04 AT. please let me know the outcome, I pretty much have the exact some mods as you and i think i might do the same spacer mod.
Thanks,
Miles
Old Mar 21, 2006 | 01:54 PM
zeof's Avatar
thnx for the review...now, i am really looking forward to getting one for my sedan.
Old Mar 21, 2006 | 02:18 PM
TheTrance's Avatar
did you torque them 90in/lbs or 110 as they say in their manual?
Old Mar 21, 2006 | 04:21 PM
The instructions I received with the spacer indicate to torque all bolts to 30in lbs, then torque all to 60in/lbs and lastly torque bolts 7-18 to 90in/lbs.
Old Mar 21, 2006 | 04:28 PM
perry05G35's Avatar
yeah 5AT folks are still on the fence considering they don't tell us if we gain any hp/tq.
Old Mar 21, 2006 | 06:13 PM
TheTrance's Avatar
im gonna give it a try in a few weeks...
Old Mar 21, 2006 | 06:22 PM
driguez's Avatar
go for it,well worth it
Old Mar 21, 2006 | 06:27 PM
ELAMINT5's Avatar
How do you do reset the ECU? Just by unhooking the battery cable like on most cars? Do you have to put in a radio code again? Thanks for the help, I am going to be buying a 1/2 inch next month. This will be a little heads up.
-dj
Old Mar 21, 2006 | 06:42 PM
TheTrance's Avatar
-dj
no not the cable.. but theres a special instruction for resetting ECU
Old Mar 21, 2006 | 06:48 PM
driguez's Avatar
i think if you leave the battery disconnected for 12 hrs the ECU resets ... heres a link with resets https://g35driver.com/forums/faq-diy/6538-ecu-resets.html
Old Mar 21, 2006 | 07:10 PM
ELAMINT5's Avatar
Thumbs up
thank you very much. Gordee is always full of excellent information isn't he.
G35VSHNG37
Oct 25, 2015 08:43 PM
Raven7
Aug 14, 2015 04:40 PM
IkonG35
Aug 10, 2015 09:33 AM
deathsupport
Canada
Aug 2, 2015 10:13 AM
