Will this work?
Old Mar 23, 2006 | 09:53 PM
Klubbheads's Avatar
Originally Posted by Chico
you must be very new to the G35 community or missed the other million posts on this subject.
Old Mar 24, 2006 | 12:08 PM
dyenboy's Avatar
Registered
Originally Posted by vodkarocket
Donnie- you need to think this decision through. Don't jump into a set of wheels, especially those with a less than optimal offset without completely understanding the implications.
It will be cheaper, and cost you much less stress if you purchsae the correct offsets off the bat (+35F/+45R). Even with +45, they will still look aggressive. You may be able to avoid fender rolling, and you won't have to run severe negative camber to make the rears fit. I'm not a fan of just "getting away" with it for $300. Spend the extra money and do it right!!!
is that your offset? I have been hearing things here and there that it will work and it won't work. Just trying to see if anyone has the same specs and was there any problems?
Old Mar 24, 2006 | 12:15 PM
vodkarocket's Avatar
Modded Member
I've got +38 in the rears, and if I could do it over again I would go +45.
Old Mar 24, 2006 | 12:39 PM
dyenboy's Avatar
Registered
wa happened?
the pic in your avatar is the type of lip I want..
Old Mar 24, 2006 | 12:50 PM
Modded Member
wa happened?
You can still get that kind of lip with +45 on the Axis Hiro's.
or...just buy my wheels, they are for sale.
Old Mar 25, 2006 | 12:42 AM
skeleton_cru's Avatar
Sedan
Originally Posted by sweettalker
Those who say it will not work has no first hand experience! Try to not give advice if you aren't sure. I am running 19x8.5 front and 19x9.5 in the rear with +35 offset with no problems. I am however running 245/35 in the front and 255/35 in the rear. Hope that helped. Oh and NO RUBBING
There are a lot more factors to be considered. Are you lowered? How much negative camber do you have? How bad does the rear wheel look with such a narrow tire? Pretty thin would be my guess.
Old Mar 25, 2006 | 12:44 AM
Sedan
Donnie, listen to the man, he speaks from experience. Don't rush into a decision you will regret later.
arora_g35
Apr 16, 2026 02:52 PM
obender66
18 Inch
Mar 13, 2016 12:20 PM
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
JMSABO
Aug 4, 2015 11:58 AM
attarday
Jul 15, 2015 04:03 PM
