Anyone got a DIY for removing the back seat in a 03 Sedan?
Old Mar 23, 2006 | 01:09 PM
BigSash's Avatar
much appreciated as always
Old Mar 23, 2006 | 01:35 PM
tkman00's Avatar
i dunno if you need a DIY, but for the seat cushion there are a total of 2 clips under the it, on e on the left one on the right. give them a good tug to unlatch either side. then lift towards the back and it should come right out.
Old Mar 23, 2006 | 02:15 PM
BigSash's Avatar
well I already knew that, sorry I should have been more clear, I meant removal of the reclining seat back, not the bench.
Old Mar 23, 2006 | 06:39 PM
vrsc's Avatar
Would like to know this too
Old Mar 23, 2006 | 07:49 PM
R2 V35's Avatar
As far as I remember. Pull the cushion out, there are bolt(s) holding the seats down on each corner, take those out and yank the seats out.
Old Mar 23, 2006 | 10:20 PM
OCG35's Avatar
PM DaveO, he removed his 03 seats to apply B-Quite (a dynomat type product for sound deadening)... He did a brief write up in SportZ mag but I don’t think it had a DIY for the seat removal... I'm sure he would share his procedure with you.
Old Apr 5, 2006 | 05:27 PM
ttrank's Avatar
Grocery getter
Remove the base with the pull-levers on each side.
Remove the two bolts (I think they were 14mm) at the base of each side holding the back in place. Note the back is three parts.
Remove each part of the parts by lifting upward and then out.
If you are still having problems let me know with a PM and I will pull a diagram from the service manual for you.
Old Apr 5, 2006 | 05:32 PM
BigSash's Avatar
thanx for the replies, won't have time to tackle this until friday so I will let you know then if I need more help.
thanks again
Old Apr 6, 2006 | 05:16 PM
da mayor's Avatar
if you need to take out the seat belts and buckles too i believe it's a torx wrench 55mm bolt size
Old Apr 6, 2006 | 05:29 PM
ttrank's Avatar
Grocery getter
55mm!! That would be HUGE!
Mine were a standard hex bolt ~14mm. The same size head as the seat back.
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
si_driver
Interior
Jul 25, 2015 09:22 AM
apintojr
Jul 23, 2015 10:52 AM
brian_z
Jul 20, 2015 01:30 AM
