conflicting info - 20x8.5 with +?offset
Old Mar 23, 2006 | 11:46 PM
MidnightClayton's Avatar
Hi,
I have searched and searched and can't find a straight forward answer.
I'm looking to put this set up on my 04 stock non-sport suspension sedan.
20 x 8.5 +40 offset with 245/35-20
Will it fit w/ no rubbing issues/problems?
Any help/pics would be greatly appreciated
(please don't yell at me if i didn't search correctly)
Old Mar 24, 2006 | 12:51 AM
godmans's Avatar
you should be fine with that =)
but wow 20s !!
Old Mar 24, 2006 | 09:39 AM
R2 V35's Avatar
but wow 20s !!
+1
Old Mar 24, 2006 | 09:56 AM
tkman00's Avatar
you'll probably ant to lower after them anyway
Old Mar 24, 2006 | 10:50 AM
Thanks guys!
I don't plan on lowering it, unless the gap drives me CRAZY.
Would it be ok with that set up even if i lower it?
Old Mar 24, 2006 | 09:03 PM
NorthSideRacing's Avatar
yes they will work. i just ordered some 20x8.5 + 35 and 20x9.5 +45 offsets. tires 245/35/20 and 275/30/20.... ill post pics this week of my sedan...
Old Mar 25, 2006 | 12:31 AM
skeleton_cru's Avatar
Sedan
You should be fine with that size/offset. Care to enlighten us on what wheels you plan to go with?
Old Mar 26, 2006 | 06:49 PM
rltaylor's Avatar
I've got 20 x 8.5 with +35 offset and same tires. I have no rubbing issues and the Eibach Pro kit goes on next week. It still needs the drop. Trust me, the gap will bug you.
Old Mar 27, 2006 | 12:10 PM
hksjza70's Avatar
I'm running 20x8.5 +32 - car is lowered (I don't have a measurement of how low it is) - but it will rub when I'm turning into a steep driveway or on a drop off to uneven pavement on the freeway. It rubs the inner fender lining - not the fender itself, so it's not a big deal at all.
rear is 20x9.5 +45 no issues whatsoever.
I'd highly recommend running a round sidewall tire (I'm running a Falken ST-115) and I had my rear fender trimmed for peace of mind. Running a flat sidewall tire (like Nitto NT-555 or BFG) will probably get you into more trouble
Old Apr 5, 2006 | 05:17 PM
ttrank's Avatar
Grocery getter
I have 20x8.5's with +20 right now and no problems. We are going to try to see if a 20x10 +43 with a 275/30/20 555 will fit in the rear on Friday.
Old Apr 5, 2006 | 05:39 PM
vodkarocket's Avatar
Modded Member
The +20 must have been a typo, right?
Old Apr 5, 2006 | 06:37 PM
rltaylor's Avatar
The Eibach kit is on now and no rubbing issues. Once again, I have 20 x 8.5's with +35mm offset. No rub, and no gap. Luv'n it....
RT
Old Apr 6, 2006 | 01:22 AM
ttrank's Avatar
Grocery getter
No, Zenetti fives. 20x8.5 +20 offset.
Old Apr 6, 2006 | 01:24 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
ttrank, are you absolutely positive you have +20, it doesnt look like you do when i saw pics of your car. they would stick out of the fender like an inch and a half.
-GP-
Old Apr 6, 2006 | 01:27 AM
ttrank's Avatar
Grocery getter
The only size the Zenetti five comes in for 20x8.5, 5x114.3 is a +20 so I am 99% sure. I could be wrong but I don't think so.
http://www.addswheels.com/?location=...20Sport%20Pkg.
