odd grinding noise
Old Apr 1, 2006 | 03:17 PM
rraabb11's Avatar
odd grinding noise
when i pull out down my driveway and hit the brackes on the desent, i hear a horrible nise that sounds like something is almost rewinding in the front end or something. i guess its the combination of sitting, being on an angle, and braking, and goes away when i stomp on the pedal. anyone know what this is from? 2005 sedan auto.
Old Apr 1, 2006 | 03:43 PM
rraabb11's Avatar
is this the "abs self check"?
Old Apr 1, 2006 | 03:49 PM
Derek S's Avatar
does it happen only once when you just start driveing the car. if yes then its the ABS check
Old Apr 1, 2006 | 04:12 PM
rraabb11's Avatar
yes, but not daily-can you explain what exactly is happening please?
Old Apr 1, 2006 | 04:45 PM
DP03's Avatar
No, this doesn't sound like ABS check to me. ABS check happens within the first few feet of driving, and that's not what he's describing (at least it doesn't sound like it). Furthermore, I would't describe the ABS check as a "horrible noise" at all. It's quiet and almost imperceptible with the radio on.
I'd say have the dealer check the brakes.
Old Apr 1, 2006 | 09:26 PM
doogie's Avatar
You're lucky. I'd say he's describing the self check pretty well.
Old Apr 1, 2006 | 10:04 PM
Sandman's Avatar
If you're headed down the driveway moving forward, not in reverse, I'd also bet it's the self-check. Mine usually occurs at about 10mph , usually when I'm about halfway down my fairly long, steep driveway. If I'm on the brakes at the time it checks, it's much louder, and you can feel it through the brake pedal. I usually creep slowly down the driveway so that the self-check doesn't occur until I'm off the brakes on a flat surface.
Old Apr 1, 2006 | 10:12 PM
getsome's Avatar
Dont worry man, its just the ABS. I had that problem for months till i found out it was the ABS.
Old Apr 2, 2006 | 03:19 AM
shredX's Avatar
Yup, brake check. It's a bit unsettling, but standard.
Old Apr 2, 2006 | 03:43 AM
Andy2434's Avatar
If it is the ABS self test, it happens for a brief second or two after the car is started and reaches some 10 mph. My car performs this said test at 10 mph . . . It may vary. Is this what you are experiencing?
Old Apr 2, 2006 | 06:23 AM
Renesis's Avatar
I think I am getting a similar sound even though I have a 03.5
Many times when I go up or down on a ramp (driveway), there is a sound similar to a scraping sound even though I went in at an angle. I don't have aftermarket suspension and my wheels are stock. It is a brief scarping type of sound but I never found out what it is when I mentioned it to service departments.
Marlin84
Apr 1, 2020 12:52 PM
magnetism80
Feb 1, 2019 10:00 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
