Just put on some Hotchkis bars
Old Apr 13, 2006 | 02:23 AM
Jeff92se's Avatar
Red Card Crew
Haven't had time to test it too much but so far so good! Easy install too.
I'm running the fronts=softest and rears=middle. Someone mentioned that's where they ended up. The Hotchkis site instructions said set both front/rear at their stiffest settings! Nuts?! I'm on a 100% stock non-sport suspension/wheels/tires.
What settings have you guys settled on?
Old Apr 13, 2006 | 06:38 AM
jimmykce1's Avatar
I did a poll with Stillen Sways and I believe most put their settings at Med for front & Rear. The next was Soft for Front and Med for Rear.
Old Apr 13, 2006 | 10:59 AM
transportchef's Avatar
I have the stillen sways set at med/frt and med/rr. Car handles nice and flat(I have a caddy butt). My butt can not tolerate a harsh ride.
Old Apr 13, 2006 | 11:44 AM
Jeff92se's Avatar
Red Card Crew
Here's the Hotchkis stiffness settings:
Stiffness settings for the front/rear sways: Front - Rate Increase over stock +9%,+32%,+63%
Rear - Increase over stock +54%,+92%,+146%
So I'm at +9% and +92% front/rear. I really want to up the front to +32% but I'll wait
Old Apr 13, 2006 | 04:05 PM
Jeff92se's Avatar
Red Card Crew
It's hard to compare the Stillen units though. The review in the suspension section just says frt/rear adj from 7% to 75% or something. What medium actually is on the frt or rear is a mystery.
Old Apr 13, 2006 | 04:31 PM
IQ9's Avatar
IQ9
I am running M/M on the htochkiss bars and it really removes the understeer. They are great!!
Old Apr 13, 2006 | 04:35 PM
Jeff92se's Avatar
Red Card Crew
Can you detail what settings you went though and the results? Thanks
Old Apr 13, 2006 | 05:40 PM
IQ9's Avatar
IQ9
We tried H/S but made things worse...Buick like...wallowed in corners. The M/M was the next though and I liked it,so I kept it. Nothing special about it...just what I feel makes driving better for my style.
Old Apr 13, 2006 | 06:52 PM
Jeff92se's Avatar
Red Card Crew
Thanks, I'll have to just continue to get seat time on each setting and see what I like
Old Apr 18, 2006 | 04:58 PM
Jeff92se's Avatar
Red Card Crew
NE1 else want to chime in?
Old Apr 18, 2006 | 05:14 PM
Steel Blue's Avatar
Is there a DIY for the install?
Old Apr 18, 2006 | 05:24 PM
Jeff92se's Avatar
Red Card Crew
Here is the pdf from the maker's site. Only thing I recommend is to ignore their intial setting recomendation.
http://www.hotchkistuning.com/bin/in...ions/22413.pdf
But in reality, you don't need the instructions. It's pretty self evident when you get under the car.
Old Apr 18, 2006 | 06:04 PM
aequitask's Avatar
when i had my hotchkis' bars on, they were on med/med, def a good place to set them, i wouldnt do stiff/stiff
Old Apr 19, 2006 | 03:05 AM
Augy's Avatar
I agree med setting was best. Best mod money I spent. I felt a big difference right away.
Old Apr 19, 2006 | 08:46 AM
DaveB's Avatar
Looks like they want you to initially set up the car for understeer. Can you just buy the rear bar?
