What RPM do you shift at
Old Sep 10, 2003 | 11:01 PM
outdoorsr's Avatar
What RPM's does everyone with the 6 shift at, and how does the shifting feel from gear to gear?
There's a monster in my garage
G Monster
Old Sep 10, 2003 | 11:12 PM
GSGNG35's Avatar
Re: What RPM do you shift at
Shifting is smooth in all gears. If I get on it, I sometimes hit the rev limiter in first (just over red line) . If I have the space I usually shift at 6000 but by the time I hit 4th , (under normal conditions) I'm up on traffic so 5th and 6th becomes just an over drive. At the same time I can even turn a corner in 5th and pull away with no hesitation.
2003.5 G35 6MT Black/Graphite
1987 GN Intercooled SFI Turbo
1970 GS 455 Stage 1 4-Speed
Old Sep 11, 2003 | 12:21 AM
kfreefall's Avatar
Monster: 4250 RPM on the way up, when I'm not in a hurry. 6000 when I am. Either way it's quite a ride
G35/S/MT....this car rocks!
Old Sep 11, 2003 | 12:30 AM
outdoorsr's Avatar
Good grief. Do you pull the shifter hard or slow through the gears?
G Monster
Old Sep 11, 2003 | 01:41 AM
nuttyprof's Avatar
from 1st to 2nd, i shift at about 2-3. 2nd to 3rd at about 3, 3rd and higher ill shift at 3-4. thats all on local roads. on the highway, its redline simply cause i can =).
my 1st to 2nd to 3rd shifts are usually smooth if im cruising. but when in a bit of a hurry, they get really screwy as if im shifting too fast. anyone else get that? its hard to get it to shift in just the right rpm drop, which for me is about 500 rpm.
G35S 6MT
K&N Typhoon intake
Technosquare ECU
350Z Springs & Struts (soon)
6-wire ground kit
Old Sep 11, 2003 | 10:20 AM
3point5SE_Auto's Avatar
6600-6800 whenever I want.
quicker shifts are better, as RPM's drop quickly.
It is real fun to sit at 80 mph in 4th gear (about 4500 rpms) and just nail it (3rd gear at 70 mph is a bit better)
this engine is made to rev, and you should.
gotta love it.
Better Life thru Chemistry
Old Sep 11, 2003 | 04:38 PM
outdoorsr's Avatar
I agree about the trans being fantastic. M prior car was a civic so this is fantastic anyway. 2nd gear snap is my fav at about 3500 rpm. Fifth is really nice to. I get into fifth and am doing 1500 RPM and can really feel the torque pulling effortlessly along with the little rumble from the exhaust.
G Monster
Old Sep 11, 2003 | 06:39 PM
InfinitiFan's Avatar
I guess because I do a lot of driving on surface streets in rush hour traffic, I don't get to redline the engine very often. Typically in the lower gears I shift at 3500 rpm. Sometimes when I'm getting on the freeway I'd go as high as 5500 rpm. Shifting is generally smooth but for some reason occasionally I have trouble putting the shifter from 5th to 6th gear.
2003.5 G35s 6MT Brilliant Silver/Graphite/Premium
Old Sep 11, 2003 | 10:08 PM
dreamsenoi's Avatar
All depends. If the car is cold and right out of the garage, I don't shift above 3000 until the engine is warmed up.
I like to shift smoothly and quickly. If I really want to pull out fast in traffic, I shift at 4500 in 1st and 2nd and 3500 in 3rd and 4th. I drive in the city most of the time, so don't have occasion to get into 5th or 6th. If I'm on a road track, I shift at higher revs--and in 4th hit the rev limiter at about 6900-7000.
Dreams garnet fire/graphite leather 6MT 2003.5 premium/aero/winter hyperground kit
Old Sep 11, 2003 | 11:29 PM
GSGNG35's Avatar
I sometimes have a problem with reverse! (you really need to push down) wish something lite up to verify when reverse was engaged. I sometimes ease of the clutch and edge forward meaning I starting out in 6th and it does not stall!!
Talk about contrast...when I go from the 6MT to driving my 70 big block with its 33 year old hurst 4 speed, its like learning to drive a stick all over again. But with 510 lbs of torque on hand , its a blast. There is nothing like cubic inches (and I use all 455 of them).
2003.5 G35 6MT Black/Graphite Prem/Aero/Winter
1987 GN Intercooled SFI Turbo (22K original miles)
1970 GS 455 Stage 1 4-Speed (#'s matching)
Old Sep 11, 2003 | 11:33 PM
nuttyprof's Avatar
when you guys shift? does the car ever jerk back or surge forward? my shifting is very quick and i dont step on the gas until my clutch is completely up. i must be doing something wrong to make it jerk or surge right? or is it my car? someone please help.
G35S 6MT
K&N Typhoon intake
Technosquare ECU
6-wire ground kit
Old Sep 11, 2003 | 11:51 PM
GSGNG35's Avatar
I suspect your traction control is causing this. Turn it off and see if you notice the difference. I turn mine off as long as the road is dry. This way I control the car and not the computer :-).
Old Sep 12, 2003 | 08:56 AM
dreamsenoi's Avatar
smcallis is definitely right. Shifting the G can be smooth as silk when you finesse all those elements the right way.
I've noticed that driving different manual cars takes some adjustment on the part of the driver because clutches and where they engage feels different. My boyfriend often has to adjust his shifting style when going from his 5-speed BMW M Roadster to my 6-spd G to make it smooth (and vice versa for me). His reverse is also in the opposite corner from mine, so we always have fun with that when driving each other's car.
As far as reverse goes, I just make sure I have depressed the stickshift before moving it over into the gate--at first it took me a little while to get the feel of that, but now it's no problem and I know right away if I'm "in" the groove for reverse or not .
