Lightweight Wheels now installed on my Sedan.
Originally Posted by G35_TX
I agree. Now I need to decide on springs. I am going to be ordering sways this week probably. I didn't get too far away from looks since these do have a similar look to the stock 18s. Just much lighter.
very light for 18s indeed.......your accel, decel will improve......look at all the unsprung weight and rotational mass you've just eliminated.....i went from stock coupe 18s to Z track wheels and felt an immediate improvement as soon as i left the shop.....easier on the brakes too......
yep, an one inch drop will do you wonders too.......
16.5 wheels, 30lb tires (due to me wanting the best performance tire I could get), so 46lb. Not bad.
From the 12/05 C&D article (shame on them for not testing the RT-615)
Braking from 50mph
KD 74.7ft
GSD 76.6ft
Neova 69.1ft
PS2 73.4ft
RT-615 ??
Autocross seconds
KD 29.76
GSD 30.05
Neova 29.66
PS2 29.92
RT-615 ??
Skidpad g's (not really worth posting but,.....)
KD .95
GSD .94
Neova .94
PS2 .93
RT-615 ??
Actually you might want to read this. It got the top best performing tire from C&D! So I am not sure where you got the not so best performing tire from. Yea if you go by numbers. But overall it is the best performing tire in all conditions from wet/dry to feel/comfort to noise and treadwear.
http://www.tirerack.com/images/tires...y_f1_gs_ds.pdf
http://www.tirerack.com/tires/tests/bs_RE050A_rd_c.jsp Tire Test results with other tires in its class.
Originally Posted by Gsedan35
But they are not the best performing tire, least not in the dry. And I found the tire's ablity to squel out loud way too much attention getting with higher outside summer temps. I do NOT care about wet grip, though I know the C&D article sure did.
Braking from 50mph
KD 74.7ft
GSD 76.6ft
Neova 69.1ft
PS2 73.4ft
RT-615 ??
Autocross seconds
KD 29.76
GSD 30.05
Neova 29.66
PS2 29.92
RT-615 ??
KD .95
GSD .94
Neova .94
PS2 .93
RT-615 ??
Braking from 50mph
KD 74.7ft
GSD 76.6ft
Neova 69.1ft
PS2 73.4ft
RT-615 ??
Autocross seconds
KD 29.76
GSD 30.05
Neova 29.66
PS2 29.92
RT-615 ??
KD .95
GSD .94
Neova .94
PS2 .93
RT-615 ??
LOL you got light wheels with the heaviest tires ever!!!! Those weigh 29lbs EACH. What is the point of getting lightweight wheels when you just bought 29lbs tires. And let me tell you I had those exact same tires for 15k miles on my sedan in the same size and the larger then stock OD made the handling so jittery and it did not handle good bottom line. I now have the conticontactsport 2s that are 23lbs each. Much better handling then when I had the good years. Im running 245/40 now vs 245/45 and the fact that they are 6lbs lighter each.
I said this in my topic that I had to make a compromise between performance and weight. The wheels saved me weight but I wanted a good high performance tire. These have high reviews and so far 75 miles I have driven on them the car has completely changed to being much smoother, more responsive.
I roadrace and needed a tire that would work good for daily and roadrace. The Conti Sport is a good tire but nothing in comparison to the tire I have now in performance. I have owned those tires before.
Not really feeling the wheels or the valve stems. IMO, the stockers look far better. The tires are it though. Even though they might be a bit heavy, they're about the best you can get. I'm sure the wheels will look a bit better once you lower it and get a little tire shine on the new rubber.
how heavy are the Z track wheels?
