Hard wireing a radar detector
Old May 3, 2006 | 11:17 PM
sliderg35's Avatar
I just ran my power wire into the headliner past the mirror then down the passenger pillar to accessory power that I sniped from the power outlet. From inside the car, you can't even see it.
Not real noticeable from outside either...
Old May 4, 2006 | 07:49 AM
Lords47's Avatar
Actually, I spliced the radar detector wires into the wires behind the rear-view mirror. Real easy, 10 minute job. Careful tho, I blew my alternator fuse doing it because the ground wire was opposite what I thought... It was the red wire vice the black, and the alternator fuse wasn't labeled in the fuse panel.
Old May 4, 2006 | 09:51 AM
some.devil's Avatar
I tapped mine into my homelink receiver. works great but I still managed to get a ticket the other day...
42 in a 30..
Old May 4, 2006 | 11:57 AM
Jeff92se's Avatar
Red Card Crew
Someone sells the hardwire if you have homelink. It's so cheap, it's not worth the hassle of making your own. I have one, great service.
https://g35driver.com/forums/audio-video-electronics/82219-v1-hardwired-2-minutes-images.html
Old Jun 13, 2006 | 02:50 AM
bigcoupee's Avatar
my way
After popping a fuse trying to hard wire my Valentine one, i want to save you the trouble. (the fuse will be labeled battery in the driver side fuse compartment if such an event were to happen)
Like the other posters, i think the piggy back V1 thing-er is too bulky to hard wire into the homelink. So what i did was cut the long straight rj12 cord to around 8 inches, stripped the tiny little wires and spliced into the home link. Very easy and very stealth. Which wires connect to which wires you ask, OK here it is:
Red RJ12 (Positive) - Black/Pink Homelink (ignition dependant positive)
Green RJ12 (Negative) - Black Homelink (Negative)
Use your favorite splice method and a little electrical tape, install your V1 just at the top left of your mirror and now its time for some irresponsible speeds.
Old Jun 13, 2006 | 10:00 AM
marvinclt's Avatar
Buy Invisicord or make one like I did....
All you need are these (http://shop4.outpost.com/product/205...:MAIN_RSLT_PG). I bought it at our local fry's (Fry's = Outpost.com.
Get any phone cord. Black if possible if you have it so it matches, but any color you want. And cut to your desired length. 6-8 inches is more than enough.
Strip (1/4 inch) the red and green lines (http://www.answers.com/topic/rj-11). If your phone cord doesnt have colored lines, just make sure you track the color done the line to the correct wire. It doesn't matter too much because its always the middle 2 and even if you connect the wrong color to the back of the homelink, it just wont work and then switch them.
Connect the connectors to the end of the lines and crimp. Use some shrink cord to clean it up. Last but most important, flatten the end of the male connector so that it will slide into the slots of the homelink. If you leave it round, it will be a very tight fit. See for connection matches ( http://www.invisicord.com/docs/quickconnect.pdf).
For Infiniti: Red to Black/Pink; Green to Black.
The red phone wire = yellow inviscord = black/pink homelink slot. The green phone wire = black invisicord = black homelink slot.
That's it. Should take you 10-30 mins to create the wire depending on your skills and 10 secs to connect to back.
Old Jun 13, 2006 | 01:14 PM
ttrank's Avatar
Grocery getter
I added the homelink to my car so the wires were up there.
You might want to look into getting Mike's mount to attach it to the mirror.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
prinny
Nov 22, 2015 11:07 PM
9tray turbo
Sep 29, 2015 10:22 PM
the93owner
Sep 28, 2015 10:37 PM
