Tein 350z H-tech
Old May 10, 2006 | 02:21 AM
killerlexus's Avatar
Tein 350z H-tech
before & after pics
Attached Thumbnails Tein 350z H-tech-img_4954.jpg   Tein 350z H-tech-img_4961.jpg   Tein 350z H-tech-img_4966.jpg
Old May 10, 2006 | 12:42 PM
vrsc's Avatar
loks good
Old May 10, 2006 | 06:15 PM
LuXXXz's Avatar
whenever i look at pictures of before and after a drop it seems like its such a big difference, but then i notice this huge gap in the before drop pics
My car doesnt have that big of a gap, its actually not too bad at all and i havent dropped it
Old May 10, 2006 | 06:30 PM
Jeff92se's Avatar
Red Card Crew
Gap doesn't look that bad until you put some wheels and low pro tires on it.
Old May 10, 2006 | 07:26 PM
LuXXXz's Avatar
you're prolly right
but he's got the coupe 18s and the gap looks crazy
Old May 10, 2006 | 08:24 PM
QuadCam's Avatar
have fun with those springs.
You have now converted your car into a massive oversteer machine!!!
Trust me, I already went the 350Z H-tech route.
The problem is that the rear springs are both too low and too high a spring rate. They totally throw off the the great dynamics of the car.
In the meantime, I put the stock sport springs back into my sedan. The car handles so much better than with the 350Z H-tech rear springs.
Tomorrow, I will have a pair of G35 H-tech rears to put in. I'll report back on how they are in comparison.
Old May 10, 2006 | 08:49 PM
mikeee2's Avatar
Is that an X or rwd G? Those are the stock 17's, not the coupe 18's right?
Old May 10, 2006 | 09:24 PM
its an X , thats why it sits sooO high , when stock.it does oversteer a little, but i llike it. if i put my sways to a lower setting it should oversteer less. but then the rotaries i go around coming home from work,wont be as much fun.
Old May 10, 2006 | 10:16 PM
QuadCam's Avatar
mine tends to oversteer a bit in stock form. I like it. Definately fun.
I hope the springs work better for you than they did for me. It was very easy to get "snap" oversteer.
I like to hang the tail out sometimes, but when I plan on doing it. What I experienced was what seemed like decent handling (lower limits though) and then "Woooaaahhhhh!!!!!" - I would be crazy sideways!!!
Old May 10, 2006 | 11:22 PM
it does get a lil squerley around tight turns. the ride is a bit stiffer then before but not bouncey or rough. havent tried any steep driveways or speedbumps yet .tomarrow the weather will be better, so i will be able to test how the car handles. hope to get a pair of 350z rear shocks from a vender, that should give the rears a little bit more dampen'n. it seems like everyone sells only as a set. anyone know where they sell dspec or bilstein shocks for just for the rear?
Old May 11, 2006 | 08:54 PM
QuadCam's Avatar
I just got the G35 H-tech for the rears. I'll probably install them tonight.
They look to be a 1/2 coil turn longer than the 350Z h-techs.
It should be interesting to see how it handles.
350Z h-techs up front / G35 H-techs in rear
Old May 12, 2006 | 12:50 AM
Gsedan35's Avatar
I ran those springs too, never ever did they remotely induce oversteer.
What are your alignment specs? Tire wear and psi? Oem sway bar's or aftermarket? What is your right foot doing when the tail is coming out?
Old May 13, 2006 | 11:42 PM
buckwilly's Avatar
Quadcam:
I'm running stock sport springs with 350z H-tech, I have only noticed better handling since added the springs. Are you running regular G shocks or the sport shocks?
Old May 14, 2006 | 01:35 AM
jjyellow's Avatar
What would be the noticable difference b/w the g and z htech. Can you get alignment into spec with the z htech without camber kit?? I am trying to decide which route to go
Old May 15, 2006 | 04:12 AM
changed sway bar setting to medium, now the ride is perfect!
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
DRG35R
Jan 31, 2016 07:14 AM
