2004 G35 Sedan with 38k miles... dealer says it needs rotors already?!
Old May 16, 2006 | 10:25 AM
NickS's Avatar
Is there a TSB on this? Isn't this a known issue with the sedan and coupe? Buddies car is JUST out of warranty and now the dealer tells him it's needed.
Any help would be appreciated.
Old May 16, 2006 | 10:54 AM
GeeWillikers's Avatar
Walking The Fine Line...
No TSB that I'm aware of. Brakes on the pre-2005s are a very well known and well documented issue. From all the things I've read here, 38K is actually above average.
Warranty covereage was extended through 3/36. Sounds like he's on his own.
Old May 16, 2006 | 12:22 PM
Lip's Avatar
Lip
I don't feel that 38k is unreasonble for sedan with 250+ hp weighing over 3500 lbs.
Old May 16, 2006 | 01:00 PM
G35_TX's Avatar
Actually there is a TSB out there for it.
Old May 16, 2006 | 02:15 PM
Noremac's Avatar
A TSB? I don't remember that. But there is a 3/36 warranty extension as the poster above mentioned.
Old May 16, 2006 | 03:19 PM
ABQ_G35's Avatar
If your "friend" bought this G used, I'm betting this is the second set of rotors, my '04 had both front pads and rotors replaced at 15k!
Old May 16, 2006 | 10:06 PM
godmans's Avatar
my dealer was too lazy to surface them, they replaced mine at like 20k KMS
lol
so yah, 38k miles seem fine to me..unless you only drive your car thru highway miles..o/w it is all good, yet, you are out of the brake warranty at 36k miles...
Old May 17, 2006 | 10:07 AM
Enlighten us please - what does it say? The only one I can find addresses brake noise (front brakes) while going in reverse. Nothing about wear.
Old May 17, 2006 | 10:12 AM
NickS's Avatar
Okay... so who know the TSB number and what it says?
Old May 17, 2006 | 10:34 AM
All the TSBs are listed for viewing over at infinitihelp.com. Here's a link. I couldn't find anything specific to brake wear like you describe.
Old May 17, 2006 | 11:31 AM
trey's wife's Avatar
My horns hold up my halo
Brake wear on the 03 and 04 G's is a known issue and that's why the 36K mile warranty includes the brakes and rotors. If your friend's car has gone 38K without needing the pads and rotors replaced then they are damn lucky. Buy some good aftermarket ones that won't wear so much and be done with it.
Old May 17, 2006 | 12:56 PM
G35_TX's Avatar
Originally Posted by BigSash
no i'm not you idiot, I read the thread, like I read most threads in the sedan forum. I have never looked at either you or your wife's public profile to see what threads you post/author.
I don't have a problem with either of you I think it is really sweet when ugly people find love with eachother and just settle.
Wow, broken 3 forum policy rules so far in this post Big Slash. Attacking Trey's wife on a continous basis is not a smart thing to do. You have done it on many posts of yours. I suggest you stop immediately.
Btw, the TSB use to be available. I had one printed for the dealer at one time 2 years ago. But now they actually have a warranty 3/36k on the brakes they decided to remove it so it seems.
https://g35driver.com/forums/showthr...ight=brake+tsb
Old May 17, 2006 | 05:48 PM
RetAF's Avatar
For some reason, many people seem to confuse a TSB with a warrenty action. `Taint so! I have seen TSB`s issued merely to correct a paragraph number or a page number. If the TSB has warrenty implications, it will say so, but most do not.
Old May 17, 2006 | 05:54 PM
G35_TX's Avatar
This was a actual TSB released before it got so bad that Nissan had to make it a warranty coverage. I had the actual TSB in my hands when I went to the dealer the first time.
Old May 17, 2006 | 09:33 PM
ABQ_G35's Avatar
Maybe it's time for a moderator to intervene here, this is getting out of hand. What's your problem Sash? Knock it off.
