quick help with wheels
Old May 16, 2006 | 12:28 PM
zeof's Avatar
will 18x8 +30 f/r with 225/40 f and 245/40 r fit on my 03.5 sedan? your help will be greatly appreciated. and, yes..i did a search..but it didn't answer my particular question. thnx in advance!!!!
Old May 16, 2006 | 12:29 PM
da mayor's Avatar
18x8 will fit but use 225/45/ and 245/45 in the rear
Old May 16, 2006 | 12:38 PM
zeof's Avatar
thnx alot da mayor...
i have a set of eibach springs for the sedan that i am giong to install once my free time is open. so, 40 should just be fine??? i don't want any rubbing issue or camber problems with these offsets.
Old May 16, 2006 | 01:22 PM
da mayor's Avatar
40 should be fine. 35-40mm offsets are good
Old May 17, 2006 | 04:15 PM
kailep's Avatar
sounds like the wheels size, offsets and tires are from the 18" G coupe. Some members have rubbing issue when lower and some don't. Maybe members will coupe's rims can chime in on this.
Old May 17, 2006 | 09:56 PM
skeleton_cru's Avatar
Sedan
+1, that offset is pushing it.
chinee
Jun 10, 2024 07:48 PM
skippyG
Jan 25, 2016 01:18 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Soumilg
Jul 18, 2015 12:33 PM
