Time to discuss wheels
Originally Posted by inTgr8r
In a high perf tire like a PS2 you can also go side to side.
(Asymetric, non-directional)
Too bad Infiniti cannot hit the BMW mark, otherwise I'd keep the setup as-is.
Originally Posted by RLampke
You got it; that's why I'm actually having the tires swapped for Michelin Pilot MXM4's - less aggressive but sporty enough, and I can rotate side-to-side w/out dismounting.
And I don't understand why Infiniti had to make different sized tires for the G. That means my fronts will wear out much faster, and then I'll have to replace all four tires well before 20k miles!
I wasn't crazy about any of the wheels I've seen thus far on the 07's. Reports so far have the sport suspension sounding kinda choppy so at this point I'm leaning towards 19 or 20s with the touring over the sport. I've got a few $$ saved up just for the right wheel package. Might lower it an inch, too.. Some of the pics have the G kinda high around the wheel wells. Have to see the wheels on the G first...
Originally Posted by DaCurryman
Well since the car is RWD, the rear will wear out faster than the fronts (if they were the same size), but since they're slightly bigger they will wear out slower than normal...possibly equalizing the wear percentage of the front & back.
Since the rims are identical, you can essentially buy the same tire size for all four, right? Why didn't I buy bigger wheels for the front of my FWD...
Originally Posted by Speedoholic
so no word if those will be "summer" tires on the sport package?
well, I'm in a 2001 M5 now and pondering going back to Infiniti b/c of the 07 G, but there is no way I would keep either of the wheel/tire setups...
on my '03 G coupe, I had 19" Volk SF winnings with 255/285 tires, and those at the time even looked a little "undersized" for my tastes - the new sedan looks like it has large arches and plenty of room for aftermarket wheels, so if I do plunk down the cash for a new sedan, I'll be doing 19's at least, but most likely I'll wait and let some other people be the guinea pigs...
at any rate, what I'm basically saying is that the current selections are undersized and dissappointing, imo...
