Smg?
The best tranny in the world is the DSG. It handles the most horsepower currently available in a production car and it shifts as smooth (or smoother) than any automatic but is technically a manual. I believe BMW and Porsche just announced plans to bring out their own DSG trannys. Can't wait till Nissan decideds to develop its own.
Originally Posted by nddl05
So whats the optimum number of gears? Is 7 a lot to go through if you are shifting yourself?
More gears gives you:
1) bragging rights
2) gearing optimized for individual speeds
Originally Posted by zmzmzm
Nissan has been playing around with CVT in some of the cars. If it can take the power, maybe it will end up in a 2008 to replace the automatic.
Does that have the potential to be even faster than the manual (keep the ratio optimal during hard acceleration?
If you listen carefully to several of the GTR spy clips you will hear what is likely a Nissan DSG transmission. Def not a regular mt and not an AT either.
It's on the way. Will it make it to the G???
Hope so; it would be so sweet. It might not be available right away, but there's a good chance that it will first be on the higher-end Infinitis first then it will trickle down the line.
Originally Posted by harrisot
Right now, their new CVT designs are exclusively FWD. You are right though, a CVT is faster than a manual - it's just not as satisfying to drive.
For the fun-to-drive part, I do agree that it will be less fun than a manual transmission. If it was significantly faster though, it might be hard to pass up.
If you added a paddle-shift setup, it would also be easy to add many "virtual" gears. I think that this approach has been used on some production cars with CVT already.
#30
I think that Nissan has a CVT in the Murano (AWD). I'm not sure why the FX35 does not use it.
The FX is rear drive and a sportier vehicle so until the technology improves it's not offered. There is a new Infiniti SUV coming out next year about the size of Murano. Maybe it will have it. The FX is being upsized with a 3rd row seat. It is expected to replace the QX56.
