Side mirror tilt on reverse
Old Nov 1, 2006 | 12:05 AM
RockyR's Avatar
Originally Posted by DWP
In addition, the backup cаmera in the Tech Package won't do much to help you avoid grinding your rіms against the curb when you parallel park. The backup cаmera shows what's behind your cаr, not how close your whеels are to the curb. A tilt-down mirror will do that nicely.
Not so sure. There are guidlines on the screen that show the position the wheels will take as you progress backwards. Keep the lines off the curb and you don't scratch the rims.
Old Nov 1, 2006 | 08:02 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
I agree...
The one time I tried it, it does show more than just the slot for the car.
It should help getting you on the right angle as you go back.
The other thing I was wondering...
Does the rear view backup system warn you as you get close to an object?
Old Nov 1, 2006 | 08:25 AM
Garnet Canuck's Avatar
Traveling Administrator
If I recall correctly from Trey's video, it beeps as you get close to an object.
Old Nov 1, 2006 | 08:30 AM
InTgr8r's Avatar
That would be great, especially in the coupe where you can't see the car behind you.
Old Nov 1, 2006 | 10:59 AM
RBull's Avatar
Rated M
I agree...
Yes it does beep. Also the view provides a fairly wide angle that gives visual feedback on how straight you are backing up - ie. curb, parking spot lines etc.
Nick_M
Aug 3, 2015 11:08 PM
Nick_M
Aug 3, 2015 05:33 PM
sailfish250
Jul 30, 2015 11:39 AM
.cakestar
Audio/Video/Electronics
Jul 17, 2015 08:22 PM
emorehs
Jul 17, 2015 09:45 AM
