Does anyone's voice learning mode
Dec 13, 2006 | 08:43 PM
involve them speaking sequences of numbers?
I see in a PDF manual that there is supposed to be a learning mode that is activated by holding down the 'speak' button for 5 seconds while the engine is running and the car is in park with the foot brake on. When I do this, nothing happens.
If I use the voice learning commands by manually going to them with the **** on the dash, I am only asked to speak command names (i.e. words).
I ask because I have tried probably 100 times to get any spoken phone number interpreted correctly but have not had a single one register ok.
Reply 0
Apr 14, 2007 | 10:34 AM
Hi...I found that same problem today. I have had the car for a week now. I got the exact results you did. Does anyone have an answer to this particular issue? Any help would be greatly appreciated.
Reply 0
Apr 14, 2007 | 11:21 AM
Hmmm....yes, seem to recall mine included sequences of numbers, which cleared up my G's ability to distinguish them (non-Nav).
Reply 0
Apr 14, 2007 | 12:00 PM
Hi...I found the answer by reading a little further along in the manual. What I had originally read concerning the "learning mode" applied to NON-NAV vehicles. I just finished the learning mode procedure for Nav vehicles and everything seems to work fine. From now on I'll double check everything I read to make sure it pretains to NAV vehicles.
Reply 0
Apr 14, 2007 | 02:36 PM
This might help ... when dialing phone numbers, try using speaking all 10 digits instead of only 7.
Reply 0
Apr 14, 2007 | 04:50 PM
Quote: This might help ... when dialing phone numbers, try using speaking all 10 digits instead of only 7.
Good advice Terry. For a while I was getting frustrated when the voice recognition wouldn't recognize the last 1 or 2 numbers when I spoke up a phone number. I then tried speaking up the whole 10 digits (including area code) even for local numbers - vualla! the system was now able to recognize the number.
Reply 0
