Rear Spolier
Originally Posted by terrycs
Looks factory! I hope they gave you a grommet at least for where the wire feeds thru the drilled hole.
Originally Posted by Sedanman07
Actually they didn't but good point. The wire shouldn't move much so I'm not to worried about it. The hole is actually much bigger (3/8") then is needed for just 2 wires.
Originally Posted by bogeydog
This may sound crazy, but who is DAWN?
http://www.sportwing.com/catalog/dis...m_subcatid=70#
Hmm .. may want to throw something in there anyway ... it's not the clearance, its the constant rubbing at the same spot on the wire over time that may pop your fuse.
Few questions... You only have to drill one hole? How's the spoiler attached?
You said you used a hair dryer on the "tape". It's taped on? This scares me.
Surely the factory spoiler is not taped on?
If it is taped on, I guess you got 1 chance to position it correctly? I would assume once you stick it on that's it?
Does it come with some kind of template to position it correctly?
What did you do before sticking it on? I've Zaino'd my car, it's pretty slick. Will tape really stick to Zaino?
You said you used a hair dryer on the "tape". It's taped on? This scares me. Surely the factory spoiler is not taped on?
After sticking it down and adding the two screws this spoiler isn't going anywhere. It fits perfectly and looks great! It's really easy to install.
Here are the directions: http://www.dawn-ent.com/Source%20Doc...nfg354dr07.pdf
