Exposing faults- The ongoing drive
Old Feb 7, 2007 | 01:19 AM
Christian's Avatar
Originally Posted by G-Whizzer
WHY, O WHY, does the voice dialing cut off at 6 characters?!?!
>> Must be a phone thing... I have the MPX220 and it works fine.
Also, I have noticed an odd thing and was wondering if any other '07 G owners have noticed this as well.
Is the Adaptive lighting system speed sensitive on the drivers side?.
>> I know the degree of turn is different for the driver's side - speed sensitive would be a good idea, since you're most likely to be driving fast on a freeway - where you won't want to shine into oncoming traffic.
And Finally, sometimes when I shut the car off, it does this infernal beeping. As if I've left the key in the ignition, but... well... there is no key in the ignition. I vacate the vehicle as per usual but after I close and lock the door, I can't tell if it's still beeping
Originally Posted by Owner's Manual
The AFS will operate:
  • when the headlight switch is ON.
  • when the selector lever is in any position other than P (Park) or R (Reverse).
  • when the vehicle is driven at above 16 MPH (25km/h) for the left-side headlight. Note that the right side low beam headlight will swivel when the vehicle is at a stop and the steering wheel is turned. The vehicle must attain a speed above 16 MPH (25 km/h) before AFS activates the left-side headlight.
As for the beeping, this happens when you turn the car off after opening the door. I have no idea why this makes any difference, but for some reason it thinks you have left the key in the ignition.
Cheers,
Christian.
Old Feb 7, 2007 | 01:20 AM
chrisbel's Avatar
Originally Posted by Derp
I have the same problem with phone numbers being truncated. It's not a 6-digit limitation though, because I tried saying the last number twice and then it gets it (Twice).. So, I can get it to accept 8 digits or 6 digits, but not 7 digits. Fortunately, I've got voice tags for my most dialed numbers, so it's not as frequent an irritation now.
I've also had it start beeping at me when I turn the car off. I think I was opening the door right as I was turning off the car. It doesn't happen often enough for me to test that hypothesis though and I haven't made any particular effort to try to recreate it.
I found that it screwed up anytime i said 7 numbers (555-0000) but if I said all ten numbers (222-555-0000) then it works most every time.
Old Feb 7, 2007 | 02:28 PM
Cyanide Ride's Avatar
Thank you for all the info, very handy indeed
I will try to use the bluetooth function with the area code and see what happens.
Old Feb 7, 2007 | 02:56 PM
gurug's Avatar
It beeps because you have some other door open. if you lock it after shutting all doors. it wont beep.
Old Feb 7, 2007 | 04:17 PM
randman's Avatar
The following is from the Infiniti G35 manual:
"Note that the right-side low
beam headlight will swivel but the left
side will not swivel when the vehicle
AFS activates the left-side headlight."
Old Feb 7, 2007 | 05:01 PM
GoofyG28's Avatar
+1. It's stupid, because you shouldn't have to say the area code of a number that shares the area code as your cell phone number. Just say all 10 digits and you'll be fine. And don't try TOO HARD to enunciate each number. Say it with a "natural" voice. If the system still has a tough time recognizing it, go to the settings and run the tutorial that "learns" your voice.
Old Feb 7, 2007 | 05:12 PM
dcmidnight's Avatar
In Northern VA at least you have to dial all 10 digits even if you're dialing your next door neighbor.
Old Feb 7, 2007 | 06:05 PM
Yup, throwing in area code works, it picks up all the numbers... Pretty lame.
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
Calvin
Southern California
12
Oct 15, 2015 04:21 PM
Jiggerjuice
Oct 5, 2015 02:33 PM
