wind noise, rear passenger side window
Old Feb 2, 2007 | 09:01 PM
gymcshoe's Avatar
Anyone get any wind noise in the rear passenger side fixed window? I start hearing it when I get on the freeway... sounds like a leak.. I think other people are having the same issue.. I called up a couple of service departments and they haven't had any other issues with this. Am I the only one?
Old Feb 2, 2007 | 09:31 PM
chuckg35's Avatar
none here i think i recall someone posting about this a while back but did not see any resolution
in my car as in some others, a sunroof seal (accordian type) came loose and bowed out inside the car with the roof inside slide open, but it is a press fit, easy to put back in place (with the sunroof window opened in the rear) and so far it seems to be holding
Old Feb 2, 2007 | 09:36 PM
terrycs's Avatar
Should be easy to re-create ... take it in.
Old Feb 3, 2007 | 10:10 AM
dahender's Avatar
http://www.infinitihelp.com/Ownershi.../ITB07-004.htm
Old Feb 3, 2007 | 04:21 PM
G-Whizzer's Avatar
Such an easy fix, even a girl can do it!
Old Feb 3, 2007 | 05:25 PM
IllSellUoNe's Avatar
i had the same problem, it is coming from the quarted window seal, i had it replaced yesterday, i had my tech look at it and he right away noticed i needed a new one, it def. fixed the problem much better...
Muski_G
Dec 1, 2023 11:11 AM
rezendvous420
May 31, 2020 01:26 PM
rping
Jul 26, 2015 09:53 PM
Thaaa_king
Jul 18, 2015 05:56 PM
