Final word on top speed?
2006 G35 6MT is limited to either 142 or 155 MPH depending on which ECU you have. 142 is the most common. I can tell you that the speedo is not super accurate at those high speeds...
The tuner version of Uprev that you're talking about gives you the ability to change anything you want (tune yourself) so you can completely remove the speed limiter if you want. I would also spring for the ARC upgrade so you get launch control, rolling anti lag, and the burnout mod. Well worth it. Shoot me an email I can help you out
Jiggerjuice
Aug 17, 2015 08:41 AM
